yzf750 rear wheel in standard trx swinger
Posted: Sun Nov 21, 2010 8:06 pm
by biker-nut-1986
will the yzf750 rear wheel fit into the standard trx swinger
long shot but worth an ask
Re: yzf750 rear wheel in standard trx swinger
Posted: Sun Nov 21, 2010 8:10 pm
Yep, although you`ll have to use different bearings as the spindle is a different diameter.Kayla will be able to help with the bushes and such like.
I WAS going to do this myself but decided against it, still have a YZF750 rear wheel complete with new cush drive rubbers for sale actually.
Posted: Sun Nov 21, 2010 8:21 pm
by biker-nut-1986
brilliant
leads me to my next question
how much again ?
Posted: Sun Nov 21, 2010 8:40 pm
by trixynut
This is a relatively easy mod.
If you look on here somewhere, you'll find a 'how-to' that I posted up when i did it.
It includes the measurements for how much to turn down the wheel spacers.
Brake disc will line up fine with the TRX caliper, may just need a small washer on the caliper bolts but thats all.
Also, need to make sure you have a sprocket with a dished/recessed side to it (like the standard one is) so you can flip it over to make the chain run straight.
and bearings for the smaller axle diamenter of the TRX
Dave.
Posted: Sun Nov 21, 2010 8:48 pm
by biker-nut-1986
that was a very useful post trixy thank you very much
now to search for that 'how to' post
ive contacted kayla for the kit but might see if i can it myself with my new lathe that ive never learnt to use bahahahahahaha
Posted: Sun Nov 21, 2010 8:55 pm
by slow codger
As Trixy says, its not hard, everything lines up no problem, just remember to turn the sprocket around. You do have less choice getting replacement sprockets, but you can still get them.
Dave E.
Posted: Sun Nov 21, 2010 8:59 pm
by biker-nut-1986
thats brilliant
found the post trixy was explaining about
1 thing i dont understand fully
the sprocket is every sprocket got this lip ?
ill probably turn the sprocket carrier down so i can fit anything as standard !
Posted: Sun Nov 21, 2010 9:03 pm
by slow codger
Nope, you can shim the original out if you want, get bling anodised ones. but with the wider wheel, they wont line the chain up, needs the dished original turned around.
Posted: Sun Nov 21, 2010 10:03 pm
biker-nut-1986 wrote:brilliant
how much again ?
The biggest problem is the postage/carriage, I could let the wheel, sprocket carrier and cush drive rubbers go for 75 quid but I`m not sure how much the carriage would be from Scotland to where, Brighton wasn`t it?
Posted: Sun Nov 21, 2010 10:11 pm
by biker-nut-1986
yea brighton bt ur down this way over xmas arnt you ?
not really interested in the cush drive sprocket carrier etc just the wheel can that be a better price or dont wanna split ?
Posted: Sun Nov 21, 2010 10:16 pm
by andyaber
Hi, Sorry to take a sideways step, but i've just fitted a yzf swing arm and wheel, should i have turned the sprocket around?
Posted: Sun Nov 21, 2010 10:19 pm
by slow codger
You need to check the sideways alignment of thr chain, it needs to be as straight as it can so that no undue force is put upon the links!
Posted: Sun Nov 21, 2010 10:21 pm
by andyaber
I only checked it by eye and it looked ok, will double check asap though.
Posted: Sun Nov 21, 2010 10:29 pm
A good straight edge will help, just hold it square against the rear sprocket face and check to see if the chain follows the same `line`.
Alternatively a cheap `sunday market` laser pointer works well too.If it`s a steel bodied one a flat bar magnet will hold it against the rear sprocket face leaving your hands free.
Craft or modelling shops sell all kind of magnets.
Posted: Mon Nov 22, 2010 6:31 pm
by biker-nut-1986
biker-nut-1986 wrote:yea brighton bt ur down this way over xmas arnt you ?
sory to be aa pain but mince i did ask this
not being rude just need an answer before i buy one
