Horny
- rbaron25
Horny
http://cgi.ebay.com.au/Stebel-Nautilus- ... 5d2c90b299
Anyone tried one of these as an upgrade to the existing horn? Was thinking it might come in handy on the link below you can hear what they sound like. With a HID 55W system and this would I be overloading the battery too much?
http://www.bikerhiway.com/stebel-nautil ... ign=banner
I didn't see you...
Cause you didn't bloody look!
BigAl-TC
Re: Horny
Hard to fit due to size. Have heard of a bloke on the FJR forum who disassembled one to get it to fit on the FJR. Have fitted one to my ex's TRX and had it hanging on the left of the motor under the rear of the fairing. I would suggest fitting a 2 trumpet set up as it can be squeezed in better. MTCW = my two cents worth
Alan.
Alan.
Re: Horny
You know I remember when I had the milk run as a kid the milkvan had a horn set up to the manifold so when you pull the lever it MOOed like a cow.. Great Idea if travelling thro India Victor set it up on the clutch lever and they will all MOOve out of the way for you and think your sacred
.... Thats my two cents worth
- rbaron25
Re: Horny
Geez my measurements must be wrong ... thought it would fit easy.... Mmmmmm
Mooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo sorry should of been an 'N' damn Cobba....
I didn't see you...
- rbaron25
Re: Horny
late but yep no dice.... Steibel no fit.... double trumpet needed.... Mmmm.
Looked at 115db but waiting on current draw. Fung said 3.5 for the standard... when would I need to use a relay... 5A?
Anyone got some seriously loud horns fitted... Alex had a set of car ones and they were double and bloody loud.
I didn't see you...
- SDN
Re: Horny
MAGNUM MSX HORN - ((black) - 136dB (with spade connectors)
£17.00
each, inc VAT
Part No: STB-MAG
Quantity:
Add To My Wishlist
Magnum MSX horn manufactured exclusively for Nippy Normans to our own design. The 'MSX' stands for Motorcycle Specific Xtreme - this is a horn designed specially for the limited space on a modern motorcyle and with features that will withstand the harsh outdoor environment encountered on a motorcyle. This is not a car horn !
This compact horn is 136dB compared to the originals 110dB and since decibels are a measurement which doubles for every 3 extra decibels , the Magnum MSX IS MUCH LOUDER THAN THE PUNY ORIGINAL HORN !!!
£17.00
each, inc VAT
Part No: STB-MAG
Quantity:
Add To My Wishlist
- fung
Re: Horny
mazda 323 horn (free from spares car)
tried to upload mp3 soundbyte .
forum system not interested in it tho.
- rbaron25
Re: Horny
Maaate 136db
thats more like it
Looked at some bmw fiamm horn stuff 2nd hand and about ten million other ones but mmmm 136db....
Where do your pipes fit Mincehead... next to your long one
thats more like it
I didn't see you...
- rbaron25
Re: Horny
Mmmm anyone want to get a MSX horn!!!! Mmmm about $52 delivered... mmmmm....
will see if they will do a postage deal for aus.... LOUD LOUD LOUD oh the POWER
I didn't see you...
Re: Horny
The plumbing`s been snipped pal, my `pipes` are not as long as they used to be!rbaron25 wrote:Maaate 136db)))))))
thats more like it![]()
Where do your pipes fit Mincehead... next to your long one![]()
The TRX pipes?
Shorter the better!
