6 sped gearbox - easily possible?
Thom
Post by Thom » Fri Jan 21, 2011 9:58 pm
Hi guys, quick question, is there a gearbox that will swap straight into a trx850 with decent ratios and a 6 speed box? Or am i just dreaming too much?
barnarda
Re: 6 sped gearbox - easily possible?
Post by barnarda » Fri Jan 21, 2011 10:05 pm
I think it might be possible using the TDM 900. Not sure of the ratios and also no idea how difficult this could be. it is an avenue i will explore.
Before i start looking into it properly i need to get a spare engine to play with.
Kayla
Post by Kayla » Fri Jan 21, 2011 10:17 pm
The YZF750 box can be used :D
Post by Mincehead » Fri Jan 21, 2011 10:28 pm
Over managed to get the YZF750 six speed box into their OV15-A racer (TDM based):
http://www.motorcycle.com/manufacturer/ ... 16115.html
So...............................
It can be done. :wink:
SDN
Post by SDN » Sat Jan 22, 2011 8:11 am
Is the YZF gearbox any better than the tarctor gearbox on the TRX? First always goes in with a crunch and it is way short of the slickest gearbox i have ever used.
Post by Killerwhale » Sat Jan 22, 2011 9:14 am
SDN wrote:Is the YZF gearbox any better than the tarctor gearbox on the TRX? First always goes in with a crunch and it is way short of the slickest gearbox i have ever used.
My thoguhts are....that it would cost more to kick in another gearbox in the trix enjun that change the enjun to a tedium900! I will add the cost up when my motorchange are done....
Thom
Post by Thom » Sat Jan 22, 2011 7:19 pm
Cheers guys!
Do we know if the yzf would be a straight swap part for part?
