Aria (over racing) pistons on evilbay :)
Posted: Sun May 08, 2011 3:50 pm
Re: Aria (over racing) pistons on evilbay :)
Posted: Sun May 08, 2011 8:51 pm
I wonder about ring availability, unless they utilise oversize stock TRX rings.
Posted: Sun May 08, 2011 9:13 pm
Mincehead wrote:I wonder about ring availability, unless they utilise oversize stock TRX rings.
Arias are pretty big in both japan & US so probably they can be sourced...!?
Posted: Sun May 08, 2011 9:24 pm
Are these definately Arias pistons kw?
Posted: Sun May 08, 2011 9:27 pm
Mincehead wrote:Are these definately Arias pistons kw?
Yes if they come from over racing they are, they used arias...and from memory the cc is correct...also the high comp...
Posted: Sun May 08, 2011 10:45 pm
Well if they`re definately Arias pistons the rings are readily available, here in the UK too.
Posted: Sun May 15, 2011 5:44 pm
So, anyone here buy those Over high comp pistons and bored block then?
Just short of 271 quid they made in the end, bit rich I thought.
Posted: Sun May 15, 2011 11:25 pm
by Kevtrx849
I was watching but when the feeding frenzy started i hopped out of the water. When the time is right i think i'll go the 900 route like killer has.
Posted: Sun May 15, 2011 11:32 pm
The seller spoke of a big end failure in the motor they came from, they `may` have kissed the head and suffered microscopic fatigue fractures. Plus, they`re heavier than oversize TRX pistons so you would very likely need to balance the crank assembly too.
Arias are good pistons, but second hand and at that price? Not for me!
Posted: Tue May 17, 2011 7:03 pm
by Runehadding
I bought them - and yes - worried about how they look...
Also bought V2 cams anf flowed head from same seller. Have TDMR with two KN`s, Laser Pro Stock, electric fuel pump so had to be next step i thought...
Anyone know where in UK I can get new piston rings for theese pistons?
Posted: Tue May 17, 2011 7:07 pm
Contact Arias UK in Billingshurst:
http://www.ariaspistons.com/distribution.html
So, are they scored, how do the crowns look?
The images on Ebay could have been better. You`re aware that they are much heavier than oversize Yamaha pistons and you should have your crank rebalanced?
Oh, forgot, hello and welcome.
Posted: Sat May 21, 2011 6:29 am
by Runehadding
Thnks.
Havent got them yet - will post and let you know. No I didnt know they are hevier.
Are TRX and TDM pistons and crank ballanse different? Going to use them in a TDM.
Great forum by the way.
Posted: Mon May 23, 2011 9:51 pm
by thch
Hi Rune.
You heathen!
Over pistons should fit in a TRX - not a TDM
If you get tired of your project, I am interested in the set for my TRX
Hilsen Thomas.
Posted: Mon May 23, 2011 10:03 pm
Runehadding wrote:Thnks.
If you`re using them in a early TDM motor then yes, the crank is a 180 degree and not 270 as in the TRX.
Posted: Tue May 24, 2011 5:59 am
by Runehadding
It will fit in a late 4TX TDM - wouldn`t it? That one has the 270 crank as the TRX?
Anyhow I`m not using it in the engine I have, I`m after a donor engine to do this build, but I didn`t know it wouldn`t fit a 180 crank...
So thanks - and if I give up the project and sell the bits, I`ll post it here.
