I oil my chain on a weekly basis ,usually after a ride and if i don't clean off the excess it drips onto the exhaust and burns itself in. After cleaning the baked on crap off i noticed that the chain has been running against the exhaust and has nearly worn through
Over exhaust system
- Kevtrx849
- Moderator
Over exhaust system
I've been a bit slack with my detailing on the bike lately
. Handsomejack shamed me into doing something about it.
Obviously i've been slack on my adjustments too. So i took the system off and took it down to my local repairer and they tigged up the gouge and put a flat area into the chain run giving more clearance. Even with the chain tensioned correctly you only get a 10-15 mm gap with these systems, now i've got like 25mm
They also took a crease out of the right hand tube from when i dropped the trackbike at Queensland raceway. All in all very happy with the work. Polished them up in my shed and refitted . All Good. Was weird running the standard headers and original cans for a couple of weeks. The carbs were twice as load as the exhaust note
( HENRY FORD )
( HENRY FORD )
Re: Over exhaust system
Nice! I´ve also left my exhaust...akra 2-1 to a local shop. Full peen blast inside/outside and then black matt heat coating (powder) all for 50£. Feels like a great deal!Kevtrx849 wrote:I've been a bit slack with my detailing on the bike lately. Handsomejack shamed me into doing something about it.
I oil my chain on a weekly basis ,usually after a ride and if i don't clean off the excess it drips onto the exhaust and burns itself in. After cleaning the baked on crap off i noticed that the chain has been running against the exhaust and has nearly worn throughObviously i've been slack on my adjustments too. So i took the system off and took it down to my local repairer and they tigged up the gouge and put a flat area into the chain run giving more clearance. Even with the chain tensioned correctly you only get a 10-15 mm gap with these systems, now i've got like 25mm
- Kayla
Veeeeeeeerrry nice!
Here´s my result, not a particle of sot inside and the black is spec @ 750 degrees...here comes the amazing part...they only asked 20£ for this...so i just had to buy a cake for ´em!!Kayla wrote:Veeeeeeeerrry nice!
- Kayla
Are you so much a fan of Chinese food that you buy boxes of prawn crackers KW?Killerwhale wrote:Here´s my result, not a particle of sot inside and the black is spec @ 750 degrees...here comes the amazing part...they only asked 20£ for this...so i just had to buy a cake for ´em!!Kayla wrote:Veeeeeeeerrry nice!
Nice headers!
very proud of you... now for the next bits ???
Al..
Al..
Nah, i got a really good ebay deal on cans for the standard headers and this is what it was sent in!Kayla wrote:Are you so much a fan of Chinese food that you buy boxes of prawn crackers KW?Killerwhale wrote:Here´s my result, not a particle of sot inside and the black is spec @ 750 degrees...here comes the amazing part...they only asked 20£ for this...so i just had to buy a cake for ´em!!Kayla wrote:Veeeeeeeerrry nice!
Nice headers!
KW - let me know how the coating holds upKillerwhale wrote:Here´s my result, not a particle of sot inside and the black is spec @ 750 degrees...here comes the amazing part...they only asked 20£ for this...so i just had to buy a cake for ´em!!Kayla wrote:Veeeeeeeerrry nice!
I've been thinking about having it done but have heard mixed reviews on the finish and what it looks like after a few rides
Will do!phuk72 wrote:KW - let me know how the coating holds upKillerwhale wrote:Here´s my result, not a particle of sot inside and the black is spec @ 750 degrees...here comes the amazing part...they only asked 20£ for this...so i just had to buy a cake for ´em!!Kayla wrote:Veeeeeeeerrry nice!
They´ve done a lot of ´em with really good results...i guess you will need to know what they use. Gonna try remember when leaving my second swinger there...
...and the bad results, have they peenshot them before? hmm
- Kevtrx849
- Moderator
Very nice killer, saves having to polish them all the time. Mine have already gone gold after just one short run.
( HENRY FORD )
( HENRY FORD )
- drix
Oh I so wish I had an Over system... can replicas be found/made for such a thing?
That one IS a replica (stainless), can be bought in Holland....real over pipes are titanium (bigger bore) and the only one i know who managed to get hold of one of those is Peder here in Sweden.drix wrote:Oh I so wish I had an Over system... can replicas be found/made for such a thing?
westrex
I have an original over system on my trx i bought off bobtrx and loving it
Adrian9912
The only place I've seen one for sale is on jauce.com, I think they only wanted 2 legs and an arm for it too. (plus shipping)
My Over system has been soft blasted to `resemble` titatinium in finish.
