R6 shock swap with pics
Marty Moose
Post by Marty Moose » Fri May 13, 2011 2:33 pm
Whwn I first looked this I couldn't find pics so here some are using Kaylas shock adapter it fits easy.
Bike on stands so shock can come out low budget just like my TRX will be.
Least I'm not using the screw driver as a punch :)
Old shock
Comparo
New shock in top bolt loose
Bottoms up my extensive bolt collection was not so extensive off to the bolt shop tomorrow
Nother one just cause I'm playing with images.
Ride report and set up to follow.
MM
kingoffifa
Re: R6 shock swap with pics
Post by kingoffifa » Fri May 13, 2011 2:51 pm
thanks for that - wondered how they worked!
Post by cobbadiggabuddyblooo » Sun May 15, 2011 10:09 am
yer 10 out of ten for this as an option for the rear end. You can't go wrong for the price so be good to hear your feedback on this also :wink:
Marty Moose
Post by Marty Moose » Sun May 15, 2011 2:48 pm
Done 300 K's on it now its much better than the stocker :) I still need to get a tape out and set the loaded and static sags no time yet! I just wound it up till the static was around 10mm and rode. I'd like to see it at around 10mm static and 25-30mm loaded, I raced on a 07 R6 and needed a harder spring will be interesting to see how this pans out more feedback to follow next the forks and some FCR's :)
MM
Post by cobbadiggabuddyblooo » Sun May 15, 2011 3:44 pm
emulators are your next cheap option and springs for the front end and FCR's are cheap from the U.S. at present with the aussie dollar
tiddsey
Post by tiddsey » Tue Jul 26, 2011 8:54 am
hello there folks, im new to the forum
just a quickie regarding this shock swap
Is it a straight swap, i.e no modifications required to make the reservoir fit?
i have fitted a cbr600 shock to a vfr 400 and it required all kings of modding to make it fit, so im not averse to a challenge.
oh and what year r6 is it from?
thanks
Post by phuk72 » Tue Jul 26, 2011 8:56 am
tiddsey wrote:hello there folks, im new to the forum
thanks
search is your friend ;)
and welcome to the forum
boogie_de
Post by boogie_de » Sun Jul 31, 2011 2:09 pm
R6 shock must be from a 06 or 07 R6, RJ11 i guess.
I've done the same modification including a 35mm high up kit and it's lot better than the the stock shock. The tire will not rip up so fast.
The One with the Terminator leg !!
Post by slow codger » Sun Jul 31, 2011 3:22 pm
:? Quick question for the guys that have done this, what is the weight difference between the the stock shock, and the R6 unit with Kaylas mod on it?
Kayla
Post by Kayla » Sun Jul 31, 2011 4:52 pm
slow codger wrote::? Quick question for the guys that have done this, what is the weight difference between the the stock shock, and the R6 unit with Kaylas mod on it?
The R6 shock is lighter :D
You need a 2006-on shock (2CO or 13S).
Post by slow codger » Sun Jul 31, 2011 5:47 pm
:D Thanks Kayla.
