R6 shock swap with pics
Posted: Fri May 13, 2011 2:33 pm
by Marty Moose
Whwn I first looked this I couldn't find pics so here some are using Kaylas shock adapter it fits easy.
Bike on stands so shock can come out low budget just like my TRX will be.
Least I'm not using the screw driver as a punch :)
Old shock
Comparo
New shock in top bolt loose
Bottoms up my extensive bolt collection was not so extensive off to the bolt shop tomorrow
Nother one just cause I'm playing with images.
Ride report and set up to follow.
MM
Re: R6 shock swap with pics
Posted: Fri May 13, 2011 2:51 pm
by kingoffifa
thanks for that - wondered how they worked!
Posted: Sun May 15, 2011 10:09 am
yer 10 out of ten for this as an option for the rear end. You can't go wrong for the price so be good to hear your feedback on this also :wink:
Posted: Sun May 15, 2011 2:48 pm
by Marty Moose
Done 300 K's on it now its much better than the stocker :) I still need to get a tape out and set the loaded and static sags no time yet! I just wound it up till the static was around 10mm and rode. I'd like to see it at around 10mm static and 25-30mm loaded, I raced on a 07 R6 and needed a harder spring will be interesting to see how this pans out more feedback to follow next the forks and some FCR's :)
MM
Posted: Sun May 15, 2011 3:44 pm
emulators are your next cheap option and springs for the front end and FCR's are cheap from the U.S. at present with the aussie dollar
Posted: Tue Jul 26, 2011 8:54 am
by tiddsey
hello there folks, im new to the forum
just a quickie regarding this shock swap
Is it a straight swap, i.e no modifications required to make the reservoir fit?
i have fitted a cbr600 shock to a vfr 400 and it required all kings of modding to make it fit, so im not averse to a challenge.
oh and what year r6 is it from?
thanks
Posted: Tue Jul 26, 2011 8:56 am
tiddsey wrote:hello there folks, im new to the forum
thanks
search is your friend ;)
and welcome to the forum
Posted: Sun Jul 31, 2011 2:09 pm
by boogie_de
R6 shock must be from a 06 or 07 R6, RJ11 i guess.
I've done the same modification including a 35mm high up kit and it's lot better than the the stock shock. The tire will not rip up so fast.
Posted: Sun Jul 31, 2011 3:22 pm
by slow codger
:? Quick question for the guys that have done this, what is the weight difference between the the stock shock, and the R6 unit with Kaylas mod on it?
Posted: Sun Jul 31, 2011 4:52 pm
by Kayla
slow codger wrote::? Quick question for the guys that have done this, what is the weight difference between the the stock shock, and the R6 unit with Kaylas mod on it?
The R6 shock is lighter :D
You need a 2006-on shock (2CO or 13S).
Posted: Sun Jul 31, 2011 5:47 pm
by slow codger
:D Thanks Kayla.
