Well it`s the early 98 to 01, 4XV-5JJ model that looks to have a sidestand that will fit. There`s plenty on Ebay UK for around twenty quid.
R1 sidestand upgrade
I seem to remember folk asking which R1 sidestand will fit the TRX.
TRiXy
Re: R1 sidestand upgrade
Of all things to upgrade... why the sidestand?? I don't get it. Does it hold the bike up faster?
Current Rides:
If you`ve `played` with ride heights, got the back jacked up to sharpen the steering etc you`ll find the stock TRX sidestand allows the bike to lean over excessively, especially if the road drops away where you park it. The R1 sidestand being a tad longer helps to address this.
Yup, mine almost fall down every f**in time!! 2 on watch!Mincehead wrote:If you`ve `played` with ride heights, got the back jacked up to sharpen the steering etc you`ll find the stock TRX sidestand allows the bike to lean over excessively, especially if the road drops away where you park it. The R1 sidestand being a tad longer helps to address this.
TRiXy
Ahh... I see... My girlfriends bike has the opposite problem... An SV650 lowered to suit a more "compact" rider... It almost falls over the RHS 'cause the stand is too long... We'll cut 'n' shut when we have the chance...
Current Rides:
- emway
Self made side-stand made of stainless steel and yes Mincehead it is robust
( emway's bike is jacked up)
It is not easy to make the right angle and make the security switch work.
- 2TWINS
Just ordered one from an R1 off e.bay, £24 delivered!
Thanks for the tip off, mine leans just that little bit too far over to be comfortable turning my back on it in the car park!
Let us know if it fits and how much longer it is - thanks2TWINS wrote:Just ordered one from an R1 off e.bay, £24 delivered!
Thanks for the tip off, mine leans just that little bit too far over to be comfortable turning my back on it in the car park!![]()
NWS870R
It does fit Phuk, just fitted one to mine - i'll measure the length later but from memory it's about 25mm.
seems more practical to carry a small piece of timber to place under the stand if that worried. don't have to worry about surface or sinkage if on grass then either.
Happy days - I have been considering welding in an extention but this option will be neater / easierNWS870R wrote:It does fit Phuk, just fitted one to mine - i'll measure the length later but from memory it's about 25mm.
I always carry a plastic Dunlop `freebie` side stand puck when out on the TRX cobba and if you really want to be flash you can drill it to accept a long cable tie.cobbadiggabuddyblooo wrote:seems more practical to carry a small piece of timber to place under the stand if that worried. don't have to worry about surface or sinkage if on grass then either.
Then you can sit on the bike, lean over and take a hold of the end of the cable tie, as you take the weight of the bike off the stand you can then swing the puck up and tuck it into your jacket or pocket. When you get REALLY good you can even put it down to meet the stand before you get off the bike too.
By the way folks I think NWS is about on the money, the R1 stand is around 25 mm longer.
Stupid question but does this work with the sidestand cut out switch?
If not, can someone give me an idiots guide (I really am crap with electrics) as to how to bypass it.
- 2TWINS
The one I've ordered from e.bay is coming with the mounting bracket, switch and link wire, so I'm guessing it'll be a direct replacement for the whole caboodle!
NWS870R
The pivot boss & sidestand switch 'actuater' are identical - just unbolt the stand from the pivot & use the TRX bracket & switch which is already on the bike, simples!phuk72 wrote:Stupid question but does this work with the sidestand cut out switch?
