Advice for rebuilding OEM Forks?
Posted: Sun May 15, 2011 9:35 am
by TRiXy
Hi all,
I remember finding some good info on rebuilding and setting up the front forks ages ago, but I can't find it again now that I need it.
Does anyone have any advice/information about how to rebuild and/or set up the forks? Diagrams etc would be nice, and suggestions on spring weights, oil weight and volume etc would be great.
Thanks and Regards
Re: Advice for rebuilding OEM Forks?
Posted: Sun May 15, 2011 10:15 am
If you google up the racetech site,it has a program on there to give you the correct spring rate for your weight
Posted: Sun May 15, 2011 11:11 am
by ekoja
Posted: Sun May 15, 2011 12:04 pm
by TRiXy
I'm not sure I should believe that calculator... Here's the results:
FRONT FORK SPRINGS
Recommended Fork Spring Rate: 0.131 kg/mm (use closest available)
Stock Fork Spring Rate: 0.5 kg/mm(stock)
Recommended spring rate is about a quarter of the standard spring rate...
Have I missed something?
EDIT:
Yep... I did... Bike weight was way off...
FRONT FORK SPRINGS
Recommended Fork Spring Rate: 0.893 kg/mm (use closest available)
That's a hell of a long way off stock... I'm amazed...
Posted: Sun May 15, 2011 12:44 pm
Bit off the mark.. .9kg/mm is favourable 80/ to 90kg for a sport/track rate as a ballpark to start from
Posted: Sun May 15, 2011 1:21 pm
by TRiXy
Yep.. That's what I got... Previous post updated with correction...
What about the rear? and what about damping etc?
Posted: Sun May 15, 2011 2:09 pm
From memory the stock TRX spring rate is suited for a 76kg rider but front springs are usually $160/200
Posted: Tue May 17, 2011 12:36 am
by M.V.
I'm 100 odd kilo's running .9 springs & 15W fork oil at the recommended level.
I also replaced the seals & few of the fork internal components at the same time, they work well for me.
