Hi guys I write from Italy. I recently bought blue spot r6 calipers and I would like to change them with the original ones. My question is: do the original (actually I have hel ones on) oil lines fit with the blue spot calipers?
Regards
Blue spot calipers
- M.V.
Re: Blue spot calipers
Greetings from Australia!
Yes & no: You can make them fit as I have done, but it's not ideal.
The bend in the banjo bolt at the caliper is not required with the bluespot calipers & the lines are slightly too long, but I simply turned the lines around so the bend go in toward the mudgaurd & that works.
Hope that helps.
Hope that helps.
