R1 Forks ??
Posted: Sat Jul 30, 2011 8:04 am
by kingy81
Hi all, first post on this forum. I have been lucky enough to buy my first TRX last week, a 96 model in pretty good nick with 16000 mls on clock. Ive only ridden it up the road and back but everything seems good to go :D . The thing is the front forks are pitted and chrome is falling off and i cant have that so from looking at other posts on here the R1 forks seem to be the way to go. Can get hold of a 2001 R1 front end with yolks etc but is it really that easy?
Will i need to adapt? Hack, grind, hammer? :dontknow:
Thanks in advance
Kingy
Re: R1 Forks ??
Posted: Sat Jul 30, 2011 9:30 am
by Kayla
kingy81 wrote:Hi all, first post on this forum. I have been lucky enough to buy my first TRX last week, a 96 model in pretty good nick with 16000 mls on clock. Ive only ridden it up the road and back but everything seems good to go :D . The thing is the front forks are pitted and chrome is falling off and i cant have that so from looking at other posts on here the R1 forks seem to be the way to go. Can get hold of a 2001 R1 front end with yolks etc but is it really that easy?
Thanks in advance
Kingy
Maybe, if you want to bake a cake. If you want to fit the R1 forks to the TRX you'll need the R1 yokes ;)
You need to swap the stems, the TRX stem needs TIG welding up and re-machining back down where it'll press into the R1 yoke because it's 0.3mm smaller than the R1 stem. You also need a top hat spacer for the R1 top yoke to sleeve it down to suit the TRX stem.
Searching is good :D
Hello, by the way.
Re: R1 Forks ??
Posted: Sat Jul 30, 2011 9:47 pm
by kingy81
I did look on other posts on here so sorry to ask again but others did seem long winded and confusing but see now what needs doing, probably cos im a bit retarded 8-[ . Im a welder so the welding part wont be a problem. I am sourcing a whole front end from R1 so should have everything i need. Id better crack on with it.
Thank you
Kingy
Re: R1 Forks ??
Posted: Sat Jul 30, 2011 9:59 pm
by cal
There are a couple o E bay right now and if you are around Essex then even better, There is one set due to end soonish and another set due ti end in a couple of days, both have forks, top and bottom yokes and spindle,
Hello! and welcome to the forum! :D
Re: R1 Forks ??
Posted: Sun Jul 31, 2011 10:55 am
by kingy81
Thanks Cal, their the ones im looking at and im only down the road from there so not far. Really want to get it sorted as the usd front end on a TRX looks spot on, plus my forks have had it.
Kingy
Re: R1 Forks ??
Posted: Sun Jul 31, 2011 7:15 pm
by NWS870R
I've got a set of fully adjustable YZF750R upside down forks c/w yokes, spindle, Harris clip ons & blue spot calipers fitted in absolute mint condition if you're interested - these are a popular mod & only require a stem change. PM me if interested?
