out with the old, in with the new
Post by alextrx850 » Wed Oct 05, 2011 11:59 am
Finally found the 2010 ..R6 shock that i liked, and armed with one of Kaylas adapters, threw it together tonight..the whole job would take an hour and a half except that my YZF rear swing has the reinforced upper and the gas resevoir on the new shock wont fit through..so its off with the rear wheel and drop the swing down while supporting the bike with axle stands and feed the shock in through the top, THEN..trim the top of the swing reo to allow travel with the shock and resevoir in place..not really a drama..
Not much to the ride height diference 4mm..[nice one Kayla].,and im sure the ride to work tomorrow will be looked foreward to much more now than OL-YELLA which had 154,000 kays up.. and if the gold resevoir is supposed to have gas in it.?
You guessed it..! #-o
And a front fender extension that ive made up for bling.
Need another road sign for a rear hugger next...and then...the whole rear seat cowl in alloy.
Re: out with the old, in with the new
Post by alextrx850 » Wed Oct 05, 2011 12:02 pm
some more photos
Post by cobbadiggabuddyblooo » Wed Oct 05, 2011 12:14 pm
got a starting point for your comp settings and rebound alex??
Post by alextrx850 » Wed Oct 05, 2011 12:25 pm
cobbadiggabuddyblooo wrote:got a starting point for your comp settings and rebound alex??
Dean has some set up info that i will go through..its probably still set for the 2010 R6 ..
Post by cobbadiggabuddyblooo » Wed Oct 05, 2011 12:53 pm
no prob.. just for your own reference as your around my weight
I've got the rebound at 10 clicks clockwise
Red/fast comp at 8 c/wise
blue/slow at 11 c/wise
Post by cobbadiggabuddyblooo » Wed Oct 05, 2011 2:06 pm
oops my mistake should be
hi and lo
