Tps Mod
Posted: Sun Oct 09, 2011 1:03 am
by zednine
Hello
i have a digital dash on my bike .......... does this mean I can just disconnect the TPs and not do any wiring changes ?
Ive got a hesitation at cruising revs that bugging me and Im wanting to check if its the Tps causing it
Thanks
Chris
Re: Tps Mod
Posted: Mon Oct 10, 2011 10:01 am
by HansJ
Disconnecting the TPS at the carbs means that it defaults to sending an error signal to the std tacho, making it go haywire. It also defaults the ignition to be set to full advanced, i.e. no revajusted settings. If you have a digital dash or not shuld not have an impact on this behaviour, unless the one who fitted it already has done the TPS-mod in order to cure the haywire signals...
