rearset plates
rearset plates
Post by fung » Tue Jan 10, 2012 11:39 pm
found these for an R1
Hey Kayla, some fellas down here showed interest in the plates i got from you.
Any chance you might make a "mark 2" version similar to the ones in the picture from oberon?
i'd be interested for one.
:rr:
Re: rearset plates
Post by fung » Wed Jan 11, 2012 10:47 am
brake side
i had a section milled out for the return spring
:rr:
Re: rearset plates
Post by Con Rod » Wed Jan 08, 2014 1:26 pm
i would also be interested, and it would give me the clearance I want for the sidestand =D> =D>
Re: rearset plates
Post by Tarwetijger » Wed Jan 08, 2014 7:43 pm
I would be interested too, because even the LSL rearset keeps hitting the tarmac during trackdays!
M.V.
Re: rearset plates
Post by M.V. » Thu Jan 09, 2014 2:20 am
That reminds me, I need to ask Kayla about some rearset plates for my VFR Project :D
Trixed
Re: rearset plates
Post by Trixed » Thu Jan 09, 2014 12:47 pm
I would be interested in a pair too.
Maybe a bulk buy Fung?
Re: rearset plates
Post by Tarwetijger » Thu Jan 09, 2014 9:52 pm
Since YZF750 rearsets are the same, these should fit the TRX too:
http://www.projection-components.co.uk/ ... -489-p.asp
:shock:
Maybe re-check with Kayla, but I'm quite sure.
Re: rearset plates
Post by dandywarhol » Thu Jan 09, 2014 10:24 pm
Re: rearset plates
Post by Tarwetijger » Fri Jan 10, 2014 7:48 am
Even better I suppose :lol:
Kayla
Re: rearset plates
Post by Kayla » Fri Jan 10, 2014 7:01 pm
The YZF and TRX plates are the same part, but I put them up on the website separately because it's easier than answering the same email a hundred times :lol:
Fung- those Oberon plates would take too long to machine (ie machined on both sides from what looks like 20mm or 25mm plate) and would have to cost around £80 per pair to make it worth doing.
As an aside, (Ian) Coxylaad has some prototype adjustable TRX rearsets from me to test at the minute. They're just roughed out from 10mm aluminium and need work but I'm getting there-
You can see the brake side is way off but the gear side is there or thereabouts. There a couple of spacing issues to sort out but nothing massive. Progress is glacial though due to work getting in the way of the fun stuff :lol:
Trixed
Re: rearset plates
Post by Trixed » Thu Jan 16, 2014 9:48 am
Kayla,
Is that an aliminium chain guard in the pic? If so any details of it?
bubbaad
Re: rearset plates
Post by bubbaad » Fri Jan 17, 2014 1:56 pm
E-bay......Just under £40 delivered. 400645052022
Kayla
Re: rearset plates
Post by Kayla » Fri Jan 17, 2014 5:13 pm
Trixed wrote:Kayla,
That's not my bike, it's Ian's (coxylaad), and he's got a Thunderace swingarm fitted to his bike.
BigAl-TC
Re: rearset plates
Post by BigAl-TC » Sun Jan 19, 2014 3:38 am
Trixed wrote:Kayla,
Go to world wide ebay, few different colours and patterns. :)
Alan.
