Gix
by Gix » Wed Feb 22, 2012 12:08 am
Hi, I've tried a search and cannot find any info....
Has anyone tried an R6 swingarm (04) on a TRX?
I managed to happen across a complete rear end, wheel, arm shock rolling and I'm toying with the idea of grafting it on.
Problem is, I am currently hiding the TRX at a mates house until I've sweet talked the missus so I can tell her I've bought it
. This makes it difficult to take measurements.
I'm used to doing, swinger/engine and front end swaps so fabbing isn't an issue, just wondered if anyone else had tried it before and if so what issues you came across
Appreciate any info
by Mincehead » Wed Feb 22, 2012 12:32 am
Another member Quan-Time has utilised an R1 swingarm but it was far from straightforward, for interest read through this thread
http://www.trx850.com/phpBB_forum/viewt ... 8&start=30
I`ve not heard of an R6 swingarm being used in a TRX but it `may` have been done.
I must say it doesn`t look like it`ll be easy:
Gix
by Gix » Wed Feb 22, 2012 12:57 am
I have already ready that thread, and this pic steered me well away from the R1 arm
It just looks too long.
I bought the rear end on a whim as I wanted a shock and it was all cheap
Looks like I'll have to drag the bits up to my mates and start doing some measurements
devlin
by devlin » Wed Feb 22, 2012 1:47 am
I've done some initial measurements and I am pretty sure it will go without too much work. I don't know above the pivot diamters and the spacing between the cradle on the main frame. The R6 swinger is just a touch longer, probably 20mm, as the pivot point on the R6 is a fair bit closer to the engine than on the TRX. I've seen the Aprilia RSV(?) swingarm used and it only required a slight removing of material from the inside of the cradle. I am going to be doing the same thing to mine, 2003 model when I get the funds and put a late model R6 front end on as well. I'm not fussed whether is Yamaha or not but it just happens that they are the two that I picked out.
Wombat
- Forum Marsupial
by Wombat » Wed Feb 22, 2012 6:09 am
like to see the piccies of that when it's done, Devlin.
devlin
by devlin » Wed Feb 22, 2012 7:18 am
Me too as it would mean it's actually done and not just talking about it.
Gix
by Gix » Wed Feb 22, 2012 7:54 am
devlin wrote:, and put a late model R6 front end on as well. I'm not fussed whether is Yamaha or not but it just happens that they are the two that I picked out.
Just so happens that I have a 2009 set of radial forks too
Stankflapper
by Stankflapper » Wed Feb 22, 2012 8:04 am
Can someone tell me what fitting a R6 swing arm does?
by Killerwhale » Wed Feb 22, 2012 8:16 am
Stankflapper wrote:Can someone tell me what fitting a R6 swing arm does?
Look modern?
Kayla
by Kayla » Wed Feb 22, 2012 8:53 am
Makes the bike even longer and steer like a boat?
by alextrx850 » Wed Feb 22, 2012 10:50 am
Gix wrote:Hi, I've tried a search and cannot find any info....
Appreciate any info
Geeez, it,d fall into the corners with the extra length...however, guessing if the swing pivot is the right diameter, and the shock be made to fit and the dog bones adjusted.......but then there is probably a thought naging as to why someone hasnt gone this way before..[which is why the question..due respect]....another however.....those aprilia banana swings are a thing of beauty...note that one from Germany that had the front and back aprilia gear..no reports on how it went though.
Can i have your motor if you make a mess of it..?
Gix
by Gix » Wed Feb 22, 2012 11:39 am
To be perfectly honest I haven't taken any measurements yet.
As I said, I bought the whole rear end as I wanted the shock and it was cheap...if I don't fit it I can sell it all on and get a shock for free
I will not be fitting it if it is too long, part of the reason I bought a TRX is the handling
My trx is currently in hiding but I will take a length measurement of the R6 swinger when I get home as well as width at pivot point, may be then someone can tell me a trx dimension to compare with.
I had thought about the Aprilia route but its all the add on that cost a fortune..Oz wheels, brembo brakes etc
Gix
by Gix » Wed Feb 22, 2012 11:45 am
Attaches the rear end of an r6 to the rest of an r6
Gix
by Gix » Wed Feb 22, 2012 11:54 am
Kayla wrote:Stankflapper wrote:Can someone tell me what fitting a R6 swing arm does?
Is that based upon swingarm measurements you have?
Just googled and found the r6 wheelbase to be 1380mm versus trx at 1435mm.
Now I know that frame head angle and swinger pivot points play a large point in that but as I said I will get my arm measurements when I get home
devlin
by devlin » Wed Feb 22, 2012 12:11 pm
it may be ashorter wheelbase on the R6 but the actual swingarm is longer. I'd be interested to see the actual dimensions of the swingarm and I'll go out the the shed and measure the frame for you.
I'm baaack. Right - the pivot 'bolt' is 20mm diameter. The sleeve that the bearings actually run on is 24.5mm diameter. The distance between the inside faces in the cradle is 255mm +/-1mm.
