Footrests
Kenvis Repesco
Footrests
Can anyone tell me if 1995 TRX footrests are the same as the 1998 model TRX footrests. I ask because I need to order some Vario adjustable footrests from M&P but they only list up to the 1995 model TRX. Any help greatfuly received...regards David.
Re: Footrests
ALL TRX footrests are unchanged through the years.
Hello and welcome by the way, oh and if you want to check on original Yamaha part numbers go to the forum`s downloads section, via the board index.
Kenvis Repesco
Re: Footrests
Thanks so much for that...very much appreciated, I shall order the footrests tomorrow. Regards David.
- Bullet
Re: Footrests
Welcome. You might also want to try raising the bars slightly, see topic.
http://www.trx850.com/phpBB_forum/viewt ... ars#p77851
I'm addicted to brake fluid, but I can stop anytime.
