R6 Rear Shock modification
MilanMule
Post by MilanMule » Mon May 14, 2012 2:20 pm
Hi everyone
Hope you knowledgeable TRX owners can help me?
I am looking to upgrade the rear shock on my 1996 TRX with an R6 unit. I have seen a 2012 R6 shock that has a black spring that I am thinking of buying. It has what I would describe as the tuning fork base that the R6/TRX adaptor fits. Can anyone explain the spring colours to me. I have seen R6 shocks with yellow and red springs but none with black. I'm guessing that the colour denotes the spring rating. Hopefully black is for the more weighty 200lb+ person.
Other than the adaptor are there any other mods I would need to carry out i.e. linkages etc for it to fit.
Any advice on settings would also be helpful.
Many thanks.
Gix
Re: R6 Rear Shock modification
Post by Gix » Mon May 14, 2012 7:54 pm
I am currently fitting a 2012 r6 shock with red spring.
I think spring colour is more to do with where the bike originates (euro/uk etc) as there are a lot of import R6's being turned into race bikes.
Spring rates are usually printed on spring.
As for lining up on TRX I lined mine up last night and there is a rectifier(I think) under the battery box which will need relocating but other than that easy... mine is linking to an RSV swingarm but through standard TRX lingages
Post by fung » Tue May 15, 2012 12:07 am
MilanMule wrote:Hi everyone
Many thanks.
Hi Mate :)
i used an '08 R6 shock with some of Kaylas shorter linkage plates and i have pushed the fork legs thru another 10mm.
some pictures ;)
TrackDaySheet.pdf
:rr:
Post by cobbadiggabuddyblooo » Tue May 15, 2012 8:07 am
check out the racetech site... There you can put all the info in on the year /R6 rear shock and it will give you the spring rate and rider weight to suit :wink:
MilanMule
Post by MilanMule » Sat May 19, 2012 5:40 pm
Thanks for the advice
Gix
Post by Gix » Sat May 19, 2012 5:44 pm
FWIW, I have a 2011/2012 rear shock, only be run in on a race bike so as new, complete with Kayla's shock adapter(new)..straight fit onto standard TRX but will not fit with my RSV swingarm....
Up for sale at £95 plus post
k0no
Post by k0no » Tue May 22, 2012 9:13 am
not sure if this is the place to discuss sales?
anyway regardless, i'd be interested in your R6 shock. my newly purchased TRX is rust-free apart from the rear shock which has seen better days (although it's still fine to use).
does it have one of those ohlins style adjusters? PM me and we'll wrangle the details.
Gix
Post by Gix » Tue May 22, 2012 2:16 pm
k0no wrote:not sure if this is the place to discuss sales?
sorry too late..... was snapped up straight away
