gaz
by gaz » Mon Jun 18, 2012 10:08 pm
Hey every body,does any one know if R1 swingarm fits in trx whithoout any mods if so what year/model is best to get,or does any one have a yzf 750 swinger i could buy ?
many thanks evry one
the mods begin he he
by Mincehead » Mon Jun 18, 2012 10:33 pm
Not without some heavy modification no, Quantime did it to his, lots of cutting and refabricating to make the R1 arm work.
Better to go with YZF750 or Thunderace arms, direct fit, plug and play, loads of threads here so SEARCH is your friend.
Stankflapper
by Stankflapper » Mon Jun 18, 2012 10:46 pm
What advantage are we looking for here?
by Mincehead » Mon Jun 18, 2012 10:51 pm
NONE in reality, just more weight, more bling and the choice of a wider tyre fitment that slows turn in!
Hey ho, each to their own.
Stankflapper
by Stankflapper » Mon Jun 18, 2012 11:00 pm
nothing like a little down spec modification
by Con Rod » Mon Jun 18, 2012 11:13 pm
I like the narrower tyre meself
by trixynut » Mon Jun 18, 2012 11:49 pm
No need to change the swinger to fit wider rim/rubber mince, the standard swinger will take the 5.5 inch / 180 tyre off a YZF with lttle modification: just some smaller spacers.
The YZF swinger is just a TRX one with some bracing welded on!
BTW the title of this thread is very misleading and lead to great disapointment on my part
Gix
by Gix » Mon Jun 18, 2012 11:53 pm
Stankflapper wrote:nothing like a little down spec modification
why does it have to be an advantage ?
Some people just like a challenge of doing something different just because they can
cal
by cal » Tue Jun 19, 2012 12:37 am
So whats in making a trx wheel fit in a YZF swingarm? A set of smaller bearings and some new spacers?
then you have bracing, turn-in and a bit of bling,
Come to think of it wouldnt the slightly raised back end from the yzf dogbones make the turn in a bit quicker anyway due to the steeper head angle?
And why is it that a wider tyre makes for slower turn in?
And whilst Im at it on the questions, whats the difference between front tyre sizes yzf/trx and wheels,I know the yzf has a bigger axle but are front rims the width?
Questions questions questions.......
Cal
bagmaker
by bagmaker » Tue Jun 19, 2012 1:37 am
damn!
this subject is nothing like what I had hoped from reading the post header.
Trolling on
those who can count
and those who cannot
SDN
by SDN » Tue Jun 19, 2012 8:24 am
cal wrote:So whats in making a trx wheel fit in a YZF swingarm? A set of smaller bearings and some new spacers?
I have been seriously considering going back to the old TRX rear wheel, in my YZF750 swinger, as I would prefer quicker turn in - who wouldn't - to bling of bigger rear
by cobbadiggabuddyblooo » Tue Jun 19, 2012 8:33 am
bagmaker wrote:damn!
Trolling on
I know ...Janet laughed at the 160 and said no wonder he wants to go bigger and then suggested viagra
cal
by cal » Tue Jun 19, 2012 10:08 am
Shoot me down in flames if this is wrong, but I will put my head above the parapet and ask another question....
If the rate of turn in is defined by the curve of the tyre (?) then wouldnt putting on a slightly wider tyre say a 190 on the yzf rim give back the turn in, this would be because you are pinching in the sidewalls slightlyand making the tyre bend round, I have looked a (very) little into this and found the 190 to be allowed by some manufacterers to be fitted to the 5.5 width rim.
I'm not suggesting or saying I am going to do this but curious about the subject now, In fact I would probably be more inclined to go for the trx wheel option as I have 3 of very good trx spare tyres now and a 3/4 worn yzf on the bike.
Cal
Gix
by Gix » Tue Jun 19, 2012 11:58 am
Snake oil
Your average rider canot tell the difference of a wider rear tyre unless significantly wider.... it's just what they've read on't internet
by cobbadiggabuddyblooo » Tue Jun 19, 2012 12:31 pm
you want more contact patch from your 160 just run a lower tyre pressure.. Go have a good chat to your local tyre dealer on the physics of tyre design .
