early fazer rear light.
leebex
Post by leebex » Sun Oct 14, 2012 9:03 pm
Anyone tried to fit an early fazer rear light to a trx? straight fit, no chance or just wants a simple bracket making up?
Might look nicer that the large square box currently fitted :lol:
Wombat
Forum Marsupial
Re: early fazer rear light.
Post by Wombat » Mon Oct 15, 2012 6:49 am
I reckon the LED tail lights from a 2001 model R6 would look tops if they would fit, too.
Post by trixynut » Mon Oct 15, 2012 9:43 am
An early r1 shotgun type fits with minor mods, is the fazerr same as that?
AndyAshworth
Post by AndyAshworth » Mon Oct 15, 2012 6:01 pm
I've had a couple of Fazers - cracking bikes for everyday use but unfortunately, fitted with a rather wide rear light.
I doubt one would fit without cutting the rear bodywork.
leebex
Post by leebex » Mon Oct 15, 2012 7:49 pm
dont want to cut body work, prefer simple bolt on mods that can be swapped back really. Still if I can pick up one cheap enough on ebay it might be worth fiddling around with :wink:
Post by fung » Mon Oct 15, 2012 9:27 pm
you could get an led unit from ebay.
They are a direct swap over bolt in job.
From lights4all, You can get clear (EBAY Item number: 300785721802) , smoked (EBAY Item number: 300786151945) or integrated indicator units (EBAY Item number: 390128876119) .
Fung
:rr:
leebex
Post by leebex » Tue Oct 16, 2012 8:08 pm
Now LED I do like, plus one less battery drain for my short commute :wink:
Post by fung » Tue Oct 16, 2012 11:11 pm
fung wrote:you could get an led unit from ebay.
Fung
:rr:
