yzf 750 forks
yzf 750 forks
Post by dixonj » Thu Jan 31, 2013 4:40 pm
Hi could someone who has yzf forks fitted to there trx do me a favour and measure the distance between the forks in the top yoke also the distance between the discs.
Cheers j
Kayla
Re: yzf 750 forks
Post by Kayla » Thu Jan 31, 2013 5:49 pm
The pitch is 210mm and I think the distance between the discs is 6mm more than the standard TRX (ie the YZF hub is 6mm wider)
Re: yzf 750 forks
Post by dixonj » Thu Jan 31, 2013 7:19 pm
Kayla wrote:The pitch is 210mm and I think the distance between the discs is 6mm more than the standard TRX (ie the YZF hub is 6mm wider)
Hi Kayla it's not the pitch distance I need but the distance between the forks it should be either 160mm or 170mm. I have just bought some r1 4xv yokes and the are 10mm narrower the the yokes fitted 160mm. #-o
Re: yzf 750 forks
Post by misterdimwiddy » Thu Jan 31, 2013 8:16 pm
My YZF front end measures up to be 160mm between the fork legs at the top yoke and 142mm between outer edges of discs (Galfer). 130mm between disc inner faces. Only measured with a tape measure though, not a vernier.
Hope this helps.
Phil
zednine
Re: yzf 750 forks
Post by zednine » Thu Jan 31, 2013 8:23 pm
Hi Dixon you can use the pitch measurement ..... just measure the inside of one fork leg hole to the outside of the other ....
Re: yzf 750 forks
Post by dixonj » Thu Jan 31, 2013 10:41 pm
misterdimwiddy wrote:My YZF front end measures up to be 160mm between the fork legs at the top yoke and 142mm between outer edges of discs (Galfer). 130mm between disc inner faces. Only measured with a tape measure though, not a vernier.
Hope this helps.
Phil
Thanks Phil it helps loads my fork bottom must be slightly different to the yzf.
Re: yzf 750 forks
Post by alextrx850 » Fri Feb 01, 2013 4:55 am
Hope this helps.
Phil
Interesting topic, so what type of fork bottom are you using ?dixonj
Re: yzf 750 forks
Post by fung » Fri Feb 01, 2013 7:53 am
:pottytrain2: :whoopass: :bootyshake:
bottom !!
Re: yzf 750 forks
Post by dixonj » Fri Feb 01, 2013 12:32 pm
Fork used are from a late FZR1000 RU 1995, which use the same wheel,disc and calliper set up as the YZF 750. The only difference I have found so far is that the FZR uses wider yokes 170mm instead of 160mm used in the YZF/R1. When I build up the forks using the R1 yokes hopefully I will be able to find out where the differences are.
Re: yzf 750 forks
Post by alextrx850 » Sun Mar 24, 2013 9:20 am
dixonj wrote:Fork used are from a late FZR1000 RU 1995, which use the same wheel,disc and calliper set up as the YZF 750. The only difference I have found so far is that the FZR uses wider yokes 170mm instead of 160mm used in the YZF/R1. When I build up the forks using the R1 yokes hopefully I will be able to find out where the differences are.
How is your FZR 1000 front fork fit up going Dixon ?
You mention the FZR has the same wheel and caliper set up...but just a wider yolk..?
Much different from my YZF 750 set with the R1 calipers..?
Re: yzf 750 forks
Post by dixonj » Sun Mar 24, 2013 11:31 am
forks look the same as the YZF750 use same wheel/discs and calipers just the yokes are 10mm wider, it would be nice to meet up with someone with the yzf forks to find out where they differ :-k
