Blue spot lines
cycloneranger
Blue spot lines
Post by cycloneranger » Mon Mar 18, 2013 9:47 pm
Just purchased some R1 side entry blue spots. (not sure of the year) Searching the forum it looks like i can use standard TRX brake lines or R1 lines. As i am buying new which ones would be best?
Jeff
Keep calm and topp up the oil
Re: Blue spot lines
Post by fung » Mon Mar 18, 2013 11:59 pm
hi mate.
i use 03/04 R6 lines on my trxs with the forks thru an extra 15mm there is a very good fit.
Fung
:rr:
Re: Blue spot lines
Post by trixynut » Tue Mar 19, 2013 12:01 am
Get trx ones cos they will be the right length.
Youve changed the calipers not the forks.
Trx ones wil fit the side entry calipers.
Re: Blue spot lines
Post by fung » Tue Mar 19, 2013 6:00 am
but ...if you have the forks through the R6 lines are the way to go .
They work :)
cycloneranger
Re: Blue spot lines
Post by cycloneranger » Tue Mar 19, 2013 8:29 pm
OK, to add to the debate I'm fitting FZR600 fox eye forks :-k
Should keep the same lenght, so I'm guessing TRX?
