Fitting digital cluster
monaro_77
Post by monaro_77 » Thu Jul 18, 2013 5:01 am
Good afternoon gentlemen,
On my current TRX project my instrument cluster is broken and I'm thinking of fitting an aftermarket gauge such as an Acewell to go with the Cafe racer look.
What I'm wondering is has any one done this before and did you run into any problems.
Any pics of your set up would also be appreciated
Thanks Anton 8)
Re: Fitting digital cluster
Post by alextrx850 » Thu Jul 18, 2013 8:04 am
works well,..best advantage is the speed is represented by a numbr ,..not a needle
monaro_77
Post by monaro_77 » Thu Jul 18, 2013 8:13 am
That looks neat as but my cluster is not existent so i was thinking of putting one that does everything like this one
[URL=http://s629.photobucket.com/user/s ... .jpg[/img][/url]
bubbaad
Post by bubbaad » Thu Jul 18, 2013 8:31 am
I've fitted a similar one and it works fine, the scary bit was cutting through the loom. I had a Haynes manual handy too which made life a bit easier....Good look with it.
monaro_77
Post by monaro_77 » Thu Jul 18, 2013 9:48 pm
bubbaad wrote:I've fitted a similar one and it works fine, the scary bit was cutting through the loom. I had a Haynes manual handy too which made life a bit easier....Good look with it.
On that note has anybody got a workshop manual i can download?
Post by cobbadiggabuddyblooo » Fri Jul 19, 2013 7:02 am
use the search and ye shall find on here
monaro_77
Post by monaro_77 » Fri Jul 19, 2013 7:12 am
cobbadiggabuddyblooo wrote:use the search and ye shall find on here
First thing under Downloads der #-o haha Thanks mate
Post by Yoozy » Fri Jul 19, 2013 8:04 am
I fitted a Koso db01r and its the biggest pile of shit I've ever spent money on. Mounting and fitting is a nightmare, just not bike friendly and the bugger is impossible to read because its so small. I'm hoping to get the original clocks mounted up on the yzf750 stay as its a lot smaller than the Trx and fit a nice screen over them to keep the crap out. I really like the older clocks 8)
Post by cobbadiggabuddyblooo » Fri Jul 19, 2013 10:20 am
Ditto.. so easy to read the stock dash. I'm just fitting a small locator on the base of the R1 forks so it mounts the speedo drive with the stock TRX wheel.
Gix
Post by Gix » Sun Jul 21, 2013 12:36 am
I have a KOSO RX2..okay not so 'cafe' but as far as wiring it was a doddle and no loom cuts required..works a treat too
Rod.s
Post by Rod.s » Sun Jul 21, 2013 1:20 pm
If you want quality then these are the only way to go.
http://motogadget.com/en/
Stu99
Post by Stu99 » Sun Jul 21, 2013 9:37 pm
Rod.s wrote:If you want quality then these are the only way to go.
Yep, I have the Motoscope Light with the Motosign. Superb piece of kit.
Post by Mincehead » Tue Jul 23, 2013 10:13 am
As the old saying goes, "you pay your money, you make your choice".
Motogadget stuff is top notch but pricey. :wink:
Stu99
Post by Stu99 » Tue Jul 23, 2013 11:07 am
Mincehead wrote:As the old saying goes, "you pay your money, you make your choice".
Too right Mince, can't buy a Porsche with Hyundai money. :lol: :lol:
Had to cop the pain to have the pleasure.
monaro_77
Post by monaro_77 » Tue Jul 23, 2013 11:15 am
Yeah i got no issue with paying good money as long as its a good quilty product. I really like the look of the top notch Acewell its got a nice finish and has been given a good rap and is only roughly $400 and does everything and more.
