Tps swop
Trxdick
Tps swop
Post by Trxdick » Wed Mar 26, 2014 2:20 pm
Hi all , will the pre 99 tps (required for fcr carbs) connect straight on to the 99 model without further mods or is there a bit more to it? Ps anybody got a spare pre 99 one :D
Re: Tps swop
Post by phuk72 » Wed Mar 26, 2014 2:52 pm
As far as I know, all TPS are the same
BTW, you don't have to use it with FCRs. I personally would recommend if you are riding on the road but you can mod to remove the need for TPS with no errors
Have a search on here for TPS mod ;)
Trxdick
Re: Tps swop
Post by Trxdick » Wed Mar 26, 2014 3:14 pm
As the bike will be used on the road I'd rather not junk the tps all together but two places I've sourced fcrs have both said that the 99 tps will be no good and an earlier one is nessesary . I don't know why , I presumed the mounting may be different ?
Re: Tps swop
Post by phuk72 » Wed Mar 26, 2014 5:58 pm
Trxdick wrote:As the bike will be used on the road I'd rather not junk the tps all together but two places I've sourced fcrs have both said that the 99 tps will be no good and an earlier one is nessesary . I don't know why , I presumed the mounting may be different ?
It's news to me if they are different
Re: Tps swop
Post by alextrx850 » Wed Mar 26, 2014 8:33 pm
Can you ask them why the TPS might be different pls, haven't heard of this and am with Phuck and wouldn't know why !
The TPS on my FCRs is a 96 and works fine.
Mounting should be the same as to the actuating spigot.
Trxdick
Re: Tps swop
Post by Trxdick » Wed Mar 26, 2014 9:12 pm
I don't know how to post a link but if you look at fcrs for Trx on the BR special tuning site you'll see what I mean :?
It says "up to and including 98 models re-use original tps , 99 on you will have to purchase tps for a pre 99 model "
Can't remember where but same thing on another sellers site
Re: Tps swop
Post by cobbadiggabuddyblooo » Fri Mar 28, 2014 4:09 pm
While on the subject of the TPS.
Can someone verify weather if fitting the tps on a pair of TDMR's you need to reverse the phasing on the wiring due to the mounting being on the opposite side??
Maybe Robert can enlighten us on this as he has tdmr's...
Re: Tps swop
Post by Tarwetijger » Fri Mar 28, 2014 7:29 pm
cobbadiggabuddyblooo wrote:While on the subject of the TPS.
It just plugs in, no prob.
SDN
Re: Tps swop
Post by SDN » Fri Apr 04, 2014 2:22 am
I have 99 bike TPS does fit straight on FCRs but I have never managed to get it adjusted right as per manual.
Re: Tps swop
Post by cobbadiggabuddyblooo » Fri Apr 04, 2014 9:22 am
Yamaha list the same part number (28 throttle sensor assembly) 4HM8588510 for all years of the trx.
I cross checked and it didn't matter which year I looked into it still came up with the same result..
The same TPS sensor was also fitted to
98 XJR1200
99-01 XJR1300 including the SP models
97-02 XJ900s (diversion)
You do need to utilize the seal from beside the TPS mounting plate either off your old carbies or pick up a new one.
DF seal ...Part number 4HM1423900
