OFD
by OFD » Mon Jun 09, 2014 6:26 pm
I have been busy over the winter spending money on the Rex and have put a YZF750R sp front end in
. My problem is with the Speedo drive
. I have the gearbox for the axle and the original TX cable fits but does not drive the Speedo. I have checked the Speedo itself with a drill attached to the end of the cable and that works but when i connect them up the speedo dos'nt work.
Any clues from thoes in the know
Thanks.
Gary
OFD on Tue Jun 10, 2014 6:49 pm, edited 2 times in total.
Motorcycling : The best fun you can have with your clothes on....
1996 TRX. Red. Leo Vince carbon cans,FCR 41 flatsides, YZF SP front, R6 shock with Projection adapter. Polished Wheel rims, Ignitech ignition. 93rwhp.. Oh yes !!
by alextrx850 » Mon Jun 09, 2014 8:07 pm
Remove the speedo drive from the wheel and inspect inside,hopefully it will be repairable...the actual drive spindle is made from brass and can sheer off if not properly lubed.
The speedo drive from the trx won't fit either as it has different axle diameter.
OFD
by OFD » Tue Jun 10, 2014 6:41 pm
Cheers Alex.
I've had it to bits and its well lubed,
and spins freely. Would it be the cable? I have swopped the cable around today but it still is not working.
Any other ideas before i buy a Vapour dash.
Gary
by trixynut » Thu Jun 12, 2014 1:53 pm
The yzf speedo drive is a plug-and-play swap for the trx so it WILL work.
You either have a knackered speedo drive or cable or speedo dial.
Check each item carefully and individually.
Cables are prone to rotting through about 1 inch from bottom, inside sleeve, cos that's where water can sit.
OFD
by OFD » Fri Jun 13, 2014 5:08 pm
So I have bought a YZF speedo cable and that didn't fix it
so it looks like the drive gearbox is NFG. So will a Thunderace/ FZR 1000 one fit or is it YZF specific ? Thanks. Gary
Rich
by Rich » Fri Jun 13, 2014 9:14 pm
jack the front end up , take the inner from the cable and stick it in the drive - hold it with some pliers and rotate the front wheel, that will show if the drive is stripped. Another thing to think of is is the inner long enough, i.e. engaging in both drives.
by cobbadiggabuddyblooo » Sat Jun 14, 2014 3:21 am
trixynut wrote:The yzf speedo drive is a plug-and-play swap for the trx so it WILL work.
So how is the setup on the yzf750 front axle out of curiosity?
Does the larger yzf axle come std with the threaded end after the bearing are milled down to 17mm so where the speedo drive sits and the end screws onto the fork leg are the same as the Trx being 17mm???
OFD
by OFD » Thu Jun 19, 2014 4:21 pm
Thanks for the advice guys. I have bought a replcement off of \ebay and will fit it tonight. The Sun has come out now so a quick run up the road to check its all OK will be in order.
Gaz
