Clutch cover gasket change
Dave C
Post by Dave C » Fri Aug 29, 2014 12:56 pm
Quick question guys. Can you change the clutch cover gasket without draining the oil first? I've got a weep from where a garage obviously failed to do the job properly.
It's just had an oil change so don't really want to do another 500 miles later.
Re: Clutch cover gasket change
Post by dandywarhol » Fri Aug 29, 2014 6:18 pm
Yes, best to lay it on it's side or well over on the side stand. A slight loss of oil will happen but only a spoonful
Red Rex
Post by Red Rex » Fri Aug 29, 2014 7:45 pm
What's wrong with draining the oil, fixing your gasket, and putting the same oil back in ??
Post by dandywarhol » Fri Aug 29, 2014 9:18 pm
Red Rex wrote:What's wrong with draining the oil, fixing your gasket, and putting the same oil back in ??
Why do it the long way? 8)
