Quick question guys. Can you change the clutch cover gasket without draining the oil first? I've got a weep from where a garage obviously failed to do the job properly.
It's just had an oil change so don't really want to do another 500 miles later.
Clutch cover gasket change
- Con Rod
Re: Clutch cover gasket change
yes, you might spill a little but with the bike on the side stand you will be fine to replace the gasket
- Kobo1
What Con Rod said or lean it further over by resting the left handlebar on a bench top or even a wall. Just chock the front wheel so it can't roll. Have fun...
Kobo
Kobo
Competing is everything, winning is just a bonus.
When the flag drops, the bullshit stops....
Dave C
Thanks guys. The answer I was looking for.
Job for next weekend I think. Are there any things I should watch out for when replacing the cover?
Dave
Dave
- Silver
I think you need to remove the circlip on top of the actuator arm and remove the actuator arm otherwise you can't get the cover off, well i couldn't.
- SDN
As silver says take the circlip and actuator arm off to get cover clear. I did mine on side stand when changing clutch with no oil coming out.
