Best Plugs?
- Mav617
Best Plugs?
Just got mine and wanting to do a plug chop - any recommendations on plug choice, heard Iridiums can be problematic?
GP100, Z200, RD250LC, CB250RS, RD250LC, GSXR400, RZ250LC, TZR250, FZR600, FZR600R, SZR660, VTR1000F, TRX850 x 2, MT-03, LCII 350 YPVS, VTR1000F
- Tarwetijger
Re: Best Plugs?
What did you hear about iridiums being problematic?
I have had them for ages, doing just fine.
bubbaad
Re: Best Plugs?
Plus one on that.
- Excalibre
Re: Best Plugs?
plus two on that, you won't need to think about spark plugs for years
Re: Best Plugs?
I had 1 fail within. 500km but that doesn't stop me from using them.
Pretty slim chance you'll get a bad one and usually it will fail shortly after fitting if its dodgey.
Benefits gained using iridium outweigh any negatives
- SDN
Re: Best Plugs?
Allways worked for me
- Stu99
Re: Best Plugs?
Thank god i just grabbed my reading glasses. Thought the thread was butt plug.
Never had an issue with iridium plugs. Certainly worth the extra $$$ in my view.
- Mav617
Re: Best Plugs?
Thanks guys, Iridiums it is then!
- skull-candy18
Re: Best Plugs?
I've heard of the tips breaking and falling into bores on high power turbo charged cars causing damage.
Never heard of a problem on motorbikes though.
- Rod.s
Re: Best Plugs?
Hang on, you say you've never had any issues with Iridium butt plugsStu99 wrote:![]()
Thank god i just grabbed my reading glasses. Thought the thread was butt plug.![]()
Re: Best Plugs?
kinky with 30,000v at 3 ohm.. Just don't have a belly full of wind or you may start pinging...
- Stu99
Re: Best Plugs?
Rod.s wrote:Hang on, you say you've never had any issues with Iridium butt plugsStu99 wrote:![]()
Never had an issue with iridium plugs. Certainly worth the extra $$$ in my view.![]()
- Stu99
Re: Best Plugs?
I'm running pressurised high octane Cobba, so no pinging issues.cobbadiggabuddyblooo wrote:kinky with 30,000v at 3 ohm.. Just don't have a belly full of wind or you may start pinging...
- Rod.s
Re: Best Plugs?
Yep, you don't want to start any scrub fires down there, you could end up with a nasty Brazilian back burnStu99 wrote:Rod.s wrote:Hang on, you say you've never had any issues with Iridium butt plugsStu99 wrote:![]()
never. But remember to use the correct plug temp for methane burn.
- Stu99
Re: Best Plugs?
Or this.......
