I've been having some serious reliability problems with my TRX lately and hoping to get an idea of what the problem might be.
The first time the problem arose was leaving work. Fired the bike up and it was idling very rough. Tacho was bouncing between 1000-6000rpm even though it was not revving anywhere near 6000rpm. Switched bike off and after a few minutes fired her up again and started no problem. Hit the road and then on the up-slope of the West Gate Bridge, bike just died. No power, no electrics. Nothing. Almost rear ended by a semi trailer that didn't notice I had stopped
Second time was riding to work on freeway and bike cut-out (same as before) but kicked back in 2 seconds later. Cut-out again and fired back up again as I pulled into servo to fill up. Went to start bike, ignition came on, then when I pressed the starter, a click noise and nothing. Had to leave bike at servo for the day. Stopped at the servo on the way home from work to give it another crack - started fine and rode home with no problems.
Went to go for a ride this weekend and as I pulled out of the driveway, bike cut-out again. No power or electrics.
Seems to be a very random problem as I have rode a few hundred kilometers between the incidents. Bike is running very well otherwise.
Thanks guys, I appreciate any suggestions, as it's not a good feeling knowing the bike might cut-out at any time.
Matt.
