Spark Plugs.
Kobo1
Spark Plugs.
Post by Kobo1 » Sun Jan 25, 2015 1:10 am
I have never had to remove a plug from this bike before as the service dudes usually do it. BUT, my plug seems to be dead and so to my question. How the hell do you get at them without dismantling half of the bike? Is there a trick? Can the radiator be flexed forward without disconnecting the hoses? And lastly, what idiot designed this engine? LOL...I guess it's the 5 valve config. that doesn't allow the plugs to come in from the side like a lot of other twins but man, what a pain.
Kobo 8)
Competing is everything, winning is just a bonus.
When the flag drops, the bullshit stops....
Re: Spark Plugs.
Post by dicky » Sun Jan 25, 2015 4:52 am
Yes.
I put Iridium plugs in mine so that I didn't have to worry about changing* them too often.
*read checking, I also can't be bothered pulling the bike half to bits.
Stu99
Re: Spark Plugs.
Post by Stu99 » Sun Jan 25, 2015 4:57 am
I undo the radiator mounting bolts, then you can move the radiator forward and a bit more out of the way.
Grab your spark plug tool and commence removing both the plugs and skin from your hands. :lol:
Don't forget to blow out those plug wells before removing the plugs.
Kobo1
Re: Spark Plugs.
Post by Kobo1 » Sun Jan 25, 2015 9:56 am
Thank you kindly Lads. I will get right on it and though exxy I like iridium plugs....
Kobo :cool:
Re: Spark Plugs.
Post by Con Rod » Sun Jan 25, 2015 1:14 pm
Kobo1 wrote:And lastly, what idiot designed this engine? LOL...I guess it's the 5 valve config. that doesn't allow the plugs to come in from the side like a lot of other twins but man, what a pain.
Kobo 8)
The idiot who designed a 5 valve dry sump engine with a 270degree crank, probably didn't account for the idiot who couldn't remove a spark plug
What an idiot!
Re: Spark Plugs.
Post by ekoja » Sun Jan 25, 2015 10:59 pm
Kobo 8)
What an idiot!
:lol: :lol:
Kobo1
Re: Spark Plugs.
Post by Kobo1 » Mon Jan 26, 2015 6:59 am
Kobo 8)
What an idiot!
What's with all the aggression Con Rod? Did I kill your dog in another life? Did you not notice the LOL after the question? It's there to point up the sacasm a bit more for the thickies who don't get i....OH Wait....
Get a grip....I love these bikes....
Kobo 8)
Red Rex
Re: Spark Plugs.
Post by Red Rex » Mon Jan 26, 2015 9:11 am
Even if you dismantle half the bike you'll still find the idiot that designed it welded a frame tube right above the spark plugs as a final "f*ck you, sucker!"
Yes, you can loosen the rad bolts to swing it forward without disconnecting the hoses to give you another 2mm of space, but you still need the delicate hands of a gynaecologist to get in.
But hey, it's just another 'character trait' of the TRX :)
Dav
Re: Spark Plugs.
Post by Dav » Mon Jan 26, 2015 9:39 pm
Also...once you get the left plug changed leave the lead off or you'll never be able to reach the right hand plug...you have to reach across the top of the left one to reach the right. Only takes about 90 mins to change 2 plugs :lol:
Re: Spark Plugs.
Post by alextrx850 » Tue Jan 27, 2015 1:20 am
I've shortened a spare yamahe plug socket and welded an old socket on top
Just remove the radiator...save damaging and it wouldn't hurt to renew the coolant anyway.
Haven't done the job a while now....iridiums.
Dav
Re: Spark Plugs.
Post by Dav » Tue Jan 27, 2015 7:33 am
Whilst doing the job, one recalls boxer twins previously owned :lol:
Rich
Re: Spark Plugs.
Post by Rich » Tue Jan 27, 2015 6:22 pm
if you think that's bad you should do the shims on a Harris Magnum 1 Z1000, you have to drop the engine to do them :D
TRX 850 #87
Re: Spark Plugs.
Post by TRX 850 #87 » Tue Feb 10, 2015 7:41 am
Geez you guys can whinge. The Trixxie is a piece of p#$s to work on compared to some bikes. Try removing the plugs from a ZX14R after at least 40 minutes to remove the necessary bodywork and lift the tank sufficiently you might be able to see the bastards. Try a '95 CBR600F3, again remove the tank, airbox, all the front bodywork, drop the radiator, remove the air intake ducts and then you can get the mongrels. Just 2 from a lifetime of working on bikes. Don't get me started on some cars or other machinery!
Dav if you've owned boxer twins before then you know they have their own problems. :wink:
For those of you who want to service your own TRX's, remove the rider's seat, disconnect your fuel hose to the pump, disconnect the vacuum lines, remove the 2 x 6mm cap screws at the front of the tank, tilt the tank back and support, then remove the airbox ( 2 x hose clamps and 2 x bolts from memory) and there are your spark plugs and valve cover. Easy as. The hardest part is doing valve clearances if you don't have the necessary replacement shims, but these can be obtained through SERCO in Brisbane. The total time to get the tank lifted and airbox off should be no more than 20 minutes if you've never done it before.
1999 TRX 850 PCRA Pre Modern F1 race bike #87
bubbaad
Re: Spark Plugs.
Post by bubbaad » Tue Feb 10, 2015 7:41 pm
Loosen rad, tilt forward, 15 minutes job done, large hands, no problem :D
bubbaad
Re: Spark Plugs.
