Front Fork Specs
Wally
Front Fork Specs
Post by Wally » Thu Feb 19, 2015 9:28 pm
Hi
I want to get my front fork tubes whats the specs on these for rechrome??
Thanks
Wally
Re: Front Fork Specs
Post by Wally » Sat Feb 21, 2015 4:14 am
Can & how do you remove the internal bush at the bottom of the fork leg??
Wally
Post by Wally » Sun Feb 22, 2015 5:59 am
This bush ,,how to get it out???
Post by Con Rod » Sun Feb 22, 2015 6:32 am
i would like to help, but not really sure what it is you want to know from the question,
Can you elaborate?
Wally
Post by Wally » Sun Feb 22, 2015 6:46 am
sorry didn't ad pic
M.V.
Post by M.V. » Mon Feb 23, 2015 11:26 pm
Is that the upper or lower Wally?
Wally
Post by Wally » Mon Feb 23, 2015 11:46 pm
lower leg its were the small white bush slides in
If you stick your finger in the inner sl
eve will rotate
These componets are not shown on the parts list at all
M.V.
Post by M.V. » Wed Feb 25, 2015 1:33 am
Stretching the memory a little, but I think as long as the stanchion is out, you shouldn't need to go any further. There is a slider in there I think, copper, with a coating on it that may need to be replaced, but I think that just slides out, perhaps with a wire clip above... It's been a long time since I had the forks apart!
