TRX temp gauge calibration
yammyman
Hi guys, I recently replaced my black dials with a set of white units, Tacho and speedo no problem but when I took the temp gauge needle off I realised the stop is on the dial and now I am unsure as to accuracy, has anyone else done this and had this issue??.....if not then I would suggest you remove the screws then allow the needle to settle in its natural stop before marking the position and removing it.
Re: TRX temp gauge calibration
Just run it till the thermo fan kicks in at 106*c
Notice the position and mark it when it kicks in and if need be remove the white sticker to reposition.
yammyman
Thanks for that info, pretty much resigned to doing it that way.
