Seat pad
- drix
Re: Seat pad
Hi & welcome
Kedo in Germany sell some if not, have yours recovered (cost me £10).
Adrien
Adrien
pbear62
Re: Seat pad
Hi Stephen,
These rear pads are still available from Yamaha but are fairly pricey - mine was AUD $180.00 six years ago!
You can get them recovered but it depends on how original you want the bike to be.
Whereabouts are you located? (This forum has members from all over the world!)
Cheers, Andy
Cheers, Andy
Re: Seat pad
I got a spurious one recently from the forum here - it looks great but it's a bit bigger than the original, so if you're a fat bastard it might not work.
Also curiously, the different size causes turbulence and a draught around the kidneys
bigstey
Re: Seat pad
Thanks for replies
I am in the north of England
And I have seen the larger ones but I am not that keen on them.
I have been wondering if it could be sprayed with some sort of plastic paint
- Wombat
- Forum Marsupial
Re: Seat pad
Black Plasti -Dip might do it
- Con Rod
Re: Seat pad
I really dont think plasti dip or any kind of paint is going to work. Simplest thing to do is get some leatherette from an upholsterer, its so small an off cut would do and just re-cover it. Assuming you have a staple gun it shouldn't cost more that a couple of quid
Failing that an upholster would probably do it on the spot for not much money
bigstey
Re: Seat pad
Plastic dip looks a good option, or I have found a new one on eBay £70 plus postage, has anybody removed it and fitted two grommets in the holes, it may be a solution
- slow codger
Re: Seat pad
goose202
Re: Seat pad
I used some thin self adhesive foam cut to shape.
Was cheap from the local rubber and plastics shop.
Rich
Re: Seat pad
I think it's a steel plate with the foam stuck to it so difficult to staple to.
