Hugger
- wreckage
Re: Hugger
Hello, Wally.
I don't have one but they are available from here:
http://www.geelongcarboncraft.com.au/pr ... GUARD.html
Cheers.
Cheers.
- Wally
Re: Hugger
Thanks
I did see that but to much cash wanted for them
Must be another model cross matches for a bit cheaper price
sdc
Re: Hugger
Check out http://www.wemoto.com.au/bikes/yamaha/trx_850/97-99/
Please let me know if you find a better option as it is on my wish-list too.
Steve
NSW, Australia
1999 Yamaha TRX850
1997 Moto Guzzi EV
NSW, Australia
1999 Yamaha TRX850
1997 Moto Guzzi EV
- fung
Re: Hugger
arrivisto
Re: Hugger
While huggers look neat and keep the rear monoshock pristine, most huggers work as a perfect device to spray water and grit directly onto the drive chain. It’s slightly absurd to use a chain-oiler and a chain spray, when the hugger is doing its best to ruin the chain and sprockets! On my TRX, I modified the carbon-fibre hugger to re-incorporate a chain guard, using a piece of sheet alloy cut to shape and pop-riveted into place. I first made a template out of cardboard, then copied it in metal and fitted it, taking great care that the mod fouled neither the chain nor the tyre. It works really well, and the chain is as good as new!
