kokoVmaxa
by kokoVmaxa » Fri Feb 26, 2016 9:30 am
My garage: CB500Four K0'71 Z440C'78 GR650XD'82 TRX850'96 TL1000R'99 S1000RR'15
by cobbadiggabuddyblooo » Fri Feb 26, 2016 12:04 pm
Isn't 1 of the main reasons they use stick coils now days is because of fuel injection?
Would not your Stick coils provide a weaker spark as they don't need to be as efficient because of the near perfect burn rate fuel delivered via the fuel injection and higher compression ratios?
Dwell time would need to be looked at from you ECU would it not???
Carbies are inefficent compared to fuel injection and one way to help things burn is to use your std 3-5 Ohm coils to acheive a good spark.
A relay is a simple way to get a more efficient spark from your std coils.
The Ignitech ignitions monitor the coils, voltage , RPM and can adjust the dwell accordingly automaticlly but I do not know if the std TRX ECU does this.
kokoVmaxa
by kokoVmaxa » Fri Feb 26, 2016 1:45 pm
.............. this is 50/50 Chance
this Ignition have 2 chance:
1st is to work around 1 min and finish ...................
2nd to accept this 1,4 ohm Coils
After the Test I have 2 options:
Buy a 4 ohm Coils or change end transistors in the Ignition box
by cobbadiggabuddyblooo » Fri Feb 26, 2016 5:43 pm
Ok bit of fishing around I found out the cbr 600 COP's are an inductive coil(just what you need
) plus they have built in drivers to deal with dwell.
Not all stick coils are the same with some late model motorcycles use a CDI ignition and those COP's won't work in an inductive style set up.
Good work
Look forward to seeing how they perform..
kokoVmaxa
by kokoVmaxa » Sat Feb 27, 2016 5:16 pm
....You mean CBR600RR COP's are usаble for any type of ignition ?
kokoVmaxa
by kokoVmaxa » Sun Feb 28, 2016 12:49 pm
......... so the Insurance of this COP's issue have a name - Volkswagen Golf 2 1.8 90 bhp commutator
by Mincehead » Sun Mar 06, 2016 11:19 am
KoKovmaxa, damn good work man!
, The exhaust is a work of TIG art and should give a nice midrange torque hike. I also notice your `port` in the pipework, is this for a temperature sensor. The proper engineering over the shock mount is nice to see too.
Mav617
by Mav617 » Sun Mar 06, 2016 8:59 pm
Looking good, nice work fella!
GP100, Z200, RD250LC, CB250RS, RD250LC, GSXR400, RZ250LC, TZR250, FZR600, FZR600R, SZR660, VTR1000F, TRX850 x 2, MT-03, LCII 350 YPVS, VTR1000F
danno
by danno » Tue Mar 08, 2016 4:44 pm
Very very good work man
the bike is really starting to look awesome. I can only dream of being good at being a mechanic
SDN
by SDN » Thu Mar 31, 2016 7:48 pm
Love it - it will look great. What you gonna do with the paint, what's the scheme?
cycloneranger
by cycloneranger » Wed Apr 13, 2016 10:02 pm
cobbadiggabuddyblooo wrote:Ok bit of fishing around I found out the cbr 600 COP's are an inductive coil(just what you need
Good work
The CBR600 stick coil mod is common on the VTR1000 firestorm. I have them on my sprint bike, they work a treat.
Keep calm and topp up the oil
by Mincehead » Fri Apr 15, 2016 3:28 pm
cycloneranger wrote:cobbadiggabuddyblooo wrote:Ok bit of fishing around I found out the cbr 600 COP's are an inductive coil(just what you need
Good work
kokoVmaxa
by kokoVmaxa » Fri Apr 22, 2016 8:39 am
wreckage
by wreckage » Sat Apr 23, 2016 1:21 am
That's a damned fine seat! Don't leave it out in the rain.
SDN
by SDN » Fri Apr 29, 2016 12:47 pm
or get a plastic cover!
