Keyster kit questions
Rubes
Post by Rubes » Thu Mar 31, 2016 4:38 am
Got me two kits from MotorcycleSparesWarehouse. My TRX is stock other than K&N airfilter, Staintune aftermarkets and Ignitech ignition. 140,000km. Given I'm in Sydney it would seem that the 142.5 main jet would be a bit rich and I should possibly get 137.5 or 140 ones instead. Just so I'm ordering the right ones can someone confirm that this is it?
http://www.motorcyclespareswarehouse.co ... h-in-round
Also I've been putting this off because the mixture screw is seized. Any tips?
Incidentally I can see that one of the kits is missing the Main Jet 75. After checking both bags 50 zillion times I'm pretty certain everything else is there. #-o
Re: Keyster kit questions
Post by Mincehead » Thu Mar 31, 2016 8:23 am
Leave the carb on it`s side overnight and fill the mixture screw tunnel with diesel oil or a good penetrating fluid. If it doesn`t shift it`s a bit of a game with easy outs. :wink:
Rubes
Post by Rubes » Sun Apr 10, 2016 1:19 pm
Tried the overnight soaking. Didn't help or more accurately didn't help initially. Tried drilling a small pilot hole and tapping in a T8 Torx head bit. Worked on the first one but the second just twisted the Torx head. Stuck for life I guess. The good news is she was idling fine before and still idles ok after refreshing the kit. Dodged a bullet methinks.
