fzr400r projector lights
hopkins800r
Post by hopkins800r » Fri Jun 10, 2016 10:58 pm
Hi,
I have an fzr400r twin projector unit with the standard bulbs, is it ok to connect it straight onto my trx loom, or does it need a relay as it has 2 bulbs? Any advice would be much appreciated.
Re: fzr400r projector lights
Post by dicky » Sat Jun 11, 2016 12:59 am
I run one wired directly to the existing connector.
Never had an issue with it.
hopkins800r
Post by hopkins800r » Sat Jun 11, 2016 9:43 am
Many thanks, I'd hoped to do just that mate, by soldering a tail light plug into the loom, it will fit the new lamps connector, then if I need to swop back to the original I can, I imagine using the original lower output bulbs doesn't put any extra strain on the system? :D
Post by dicky » Sat Jun 11, 2016 10:41 am
I've made a small loom with spade terminals to fit into the headlight socket, hasn't failed me yet.
I ran a 100W globe in the original headlight in the vain attempt to get better night vision, and it had no detrimental affect on the wiring, I'm not concerned about the twin globes.
Most wiring is able to handle 10 amps at 12v, it's way overspec'd but if it was made to barely cope then it would break from vibration.
hopkins800r
Post by hopkins800r » Sat Jun 11, 2016 5:58 pm
Many thanks for your input, I reckon its always better to ask first, saves any embarrassing stuff ups! Cheers.
Overlord Neil
Post by Overlord Neil » Sun Jun 12, 2016 2:24 am
My FZR400 headlamp came with the original loom stub, which wires both bulbs into one terminal socket. I de-pinned the terminal and replaced it with an H4/7 (forget which) so I could plug it straight into the original TRX loom, no problem.
