???? help
- Steelback
???? help
Have been having problems with my TRX running rough under 3000 rpm and using a lot of fuel and also flooding easily.I have fitted a new air filter and repair kits for the carbs ( on stripping they were very clean and not flooded ), I have also fitted new NGK plugs but the b***ch still wont start and keeps flooding - what else could it be??????
- phuk72
What have you done to the carbs? New emulsion tubes? New jets? Float bowl set correctly?
Check all of the hoses and also that fuel tap is not on prime (and that the kill switch is off!)
If you are getting fuel then the problem is most likley due to the spark? Are you getting a spark? Are the plugs gapped correctly?
