After balancing the float bowls yesterday, I was hopeful this afternoon would generate results... Carbs back on the bike, fires up without an issue, still refuse to pull from idle.
As a sanity check, I did a compression check on both cylinders, 150psi in both; not ideal but losses could be in the equipment atleast they are both the same and within limits.
Rechecked the valve timing, checked all the indicators; lobes out on cylinder 1, cam sprocket marks align inlet and exhaust, cam shaft dots align with cam retainers, so thats all good.
Pulled one of the carbs apart, all the jets are clear, blew through all the passages to check they aren't blocked, will do the same with the other then I'm struggling for ideas.
The inlet boots are showing some crazing but it looks superficial, even if there were some air bypass it wouldn't limit the revs to 2-2,500, would it? On both cylinders?
The only other thought I had was that the spark timing is out. I'm ashamed to admit it, but when I was trying to get it running a few weeks back I drained the battery so jumped it off the car... and got the leads the wrong way around
I checked the main fuse, it hadn't blown so figured it was a lucky escape, could I have fried the ignitech box? Its still appears to function properly, the bike starts, my laptop talks to it fine and i can reflash the ignition map etc.
It 'feels' like a fuel issue but I'm struggling. Any thoughts?
