by cobbadiggabuddyblooo » Fri May 12, 2017 3:06 am
Below is a photo from one of the OEM Yamaha grade 2 carbon steel engine case bolts from the bottom engine pan. Once the work was done, and tightening up to 10Nm I could feel the bolt stretching so I removed it straight away and just in time.
Hardened steel and even stainless has a tendency not to yield as much and just snap or gall the thread to cause more problems.
by Tarwetijger » Fri May 12, 2017 7:35 am
by Con Rod » Fri May 12, 2017 7:36 am
yes I would tend to agree for thinks like your sump plugs, mounting bolts, caliper bolts etc, but for you standard cap screws for the clutch etc stainless is great for its properties
by cobbadiggabuddyblooo » Fri May 12, 2017 9:27 am
I've been reminded it's a screw not a bolt....
GDTA
by GDTA » Sun Aug 20, 2017 7:41 am
A screw is conical,a bolt is not,its a common misuse of a word
by dandywarhol » Sun Aug 20, 2017 11:55 am
And a setscrew is threaded all the way whereas a bolt has a plain portion before the thread
andyaber
by andyaber » Sun Aug 20, 2017 1:11 pm
A screw is only conical if we are talking woodwork, self tappers or diy. Here we are talking engineering where a screw is threaded all the way to the head, (a set or grub screw is headless) and a bolt is threaded for part of the shaft and plain up to the had.
andyaber
by andyaber » Sun Aug 20, 2017 1:25 pm
Wouldn't it be good if Usain Bolt had a brother called Allen?
by cobbadiggabuddyblooo » Mon Aug 21, 2017 7:18 am
He has a cousin called caphead
Rod.s
by Rod.s » Mon Aug 21, 2017 12:00 pm
or Phillip
andyaber
by andyaber » Mon Aug 21, 2017 1:10 pm
Didn't want to hi jack the THREAD with any COARSE humour but i think i PITCHed it just right.
Racer-unk
by Racer-unk » Mon Aug 21, 2017 1:20 pm
I am not H-phobic, but just to let you know....Phillip is not straight!
