you clearly know the track...bike looks fast
Nice footage...
The TRX900 Project kicks off
- Racer-unk
Re: The TRX900 Project kicks off
I am not sure what benefit I would get from shortening my gears. I sometime let the revs drop and roll through certain corners in a higher gear than I really should, as it seems to get my corner speed up and the bike is more placid, therefore I can be a bit more aggressive with the throttle.dandywarhol wrote:Good one. Consistent lines!
Only using 3 gears (apart from moving off)? Have you considered downgearing it and using the upper ratios which are closer spaced? #just thinkin'
3rd 4th and 5th are the gears I use (I think) but I could be down into 2nd at the hairpin and mansfield
engines getting removed anyway so its a bit of a moot point!
