Engine dies.
bikefiddler8
Engine dies.
Post by bikefiddler8 » Mon Jul 08, 2019 8:54 am
Hi,
Can anyone help ?
I've had my TRX for 14 years and had few problems but it recently started running badly at low speeds .
So i stripped and cleaned the carbs ( found a blocked pilot jet) and fitted new seals and o-rings which seems to have solved the issue but now the throttle dies when i rev to about 3500 rpm.
It's never happened before , any idea what i've done ?
Thanks.
Re: Engine dies.
Post by Tarwetijger » Mon Jul 08, 2019 11:47 am
Worn out needle tubes?
HolerTogni
Re: Engine dies.
Post by HolerTogni » Mon Jul 08, 2019 5:54 pm
Hi bikefiddler8!
My guess is a "folded" (and thus narrowed) vacuum hose to the fuel tap or fuel hose.
Or something completely different ...
Tele diagnosing greets from Munich!
TRX 850 & Racetrack-TRiXie
bikefiddler8
Re: Engine dies.
Post by bikefiddler8 » Tue Jul 09, 2019 10:51 am
Hi Holer,
Thanks.
I think it is something like that , the engine will run with the choke so i'm thinking too much air as in a leak somewhere or the fuel is restricted.
It's just finding it.
Cheers.
