Swingarm lateral movement.
bubbaad
Post by bubbaad » Tue Apr 28, 2020 5:19 pm
Fitting a yzf750 swingarm that was on another TRX and there is lateral movement, about 10mm when it's bolted onto the subframe which it fits into perfectly. Am I missing something obvious here ? Just doesn't seem right. Any help appreciated thanks.
Tealman
Re: Swingarm lateral movement.
Post by Tealman » Tue Apr 28, 2020 10:08 pm
Did you remember to put the bearings in :lol: :lol: :lol:
bubbaad
Post by bubbaad » Tue Apr 28, 2020 10:45 pm
The needle bearings were never taken out. The movement is side to side along the length of the pivot.
jpe70
Post by jpe70 » Wed Apr 29, 2020 7:57 pm
Sounds like you are missing end caps on the swing arm. Still, 10 mm is a lot... :shock:
andyaber
Post by andyaber » Wed Apr 29, 2020 9:13 pm
Seem to remember spacers inside the end caps maybe. Think I looked at exploded diagrams at local bike shop n ordered them. Cheers, Andy.
bubbaad
Post by bubbaad » Wed Apr 29, 2020 9:42 pm
End caps are on, swingarm fits into the subframe as it should. I must be missing something obvious......
Post by cobbadiggabuddyblooo » Thu Apr 30, 2020 1:06 am
Did you get 2 spacers???
Post by dicky » Thu Apr 30, 2020 2:20 am
Just a note in case you are looking at the parts manual or online parts finder...
The part number for the swing arm pivot shaft is 3GM-22141-01.
Both the manual and the online parts finder show the rear axle part number 3BN-25381-00 instead.
Although they share the same pivot shaft, the parts list for the YZF swingarm shows two shims (3XV-22127-00, #4 on the diagram) that are not part of the TRX setup, so maybe these are the parts you are looking for.
Diagram here... http://yamahaoemparts.com.au/partFinder ... tid-850445
bubbaad
Post by bubbaad » Thu Apr 30, 2020 11:21 am
Cheers guys, it's the spacers/shims. I must have them somewhere........I hope......
Post by Tarwetijger » Fri May 01, 2020 10:43 pm
A bit late but I do remember the YZF swingarm had spacers fitted were the original TRX one hadn't. They were located under the end caps if I recall correctly.
