Carb joint rubbers (I.D please)
00mike00
Post by 00mike00 » Fri May 07, 2021 7:59 am
Hi all,
I need to replace perishing rubbers on the lower joints of my 98' TRX.
Upon searching these came up...
EBAY LINK
The image shown is not of a TRX carb and also showing the airbox to carb joint, not the lower two. Are they simply the same part of different rubbers altogether?
Thanks
Rod.s
Re: Carb joint rubbers (I.D please)
Post by Rod.s » Fri May 07, 2021 5:16 pm
They are correct for the TRX, the sectional image is for the TDM.
I would also check that price with your local dealer as it seems high.
00mike00
Post by 00mike00 » Sun May 09, 2021 8:05 am
Rod.s wrote:They are correct for the TRX, the sectional image is for the TDM.
Thank you, I will check!
Post by Tarwetijger » Tue May 11, 2021 12:04 pm
