Sorry for repetition...sprockets....
- Killerwhale
Just wanted to verify that i remember correctly here....
It´s this TDM kit wich also fits TRX right!?
KETTENSATZ YAMAHA TDM 850 (4TX)
TDM850 BJ96-98(114/17/42)
- Killerwhale
Yeah, i want to go 17/42 instead of 16/39.martin young wrote:96 - 98 TDM front sprocket is the same as TRX but I think the rear is different. TDM900 rear is the same as TRX I think.
PCD of 850 is 140mm
PCD of TRX and 900 is 150mm
But could be wrong
Also stock rear on TRX is 39 tooth
Guess i just buy pieces then....for safety!
Although im pretty sure one of the TDM 850 kits where a fit....there are three different...hmmmm.
- Killerwhale
- Killerwhale
- twinlovin
If you dont want to cut out some links I have a 48 rear sitting on the garage wall.
It's a bit ambitious for my chain at the moment.
I have 16/39 fitted. I didn't realise a 42 was so easily available. Always getting stooged down at the bike shop with them saying "nah mate this wont fit, that wont fit."
Good luck getting the right one mate.
Tyres are evil and must be punished
- jpe
- Killerwhale
Ahh, it was the front of the TDM 850 wich fits!jpe wrote:Worked for me, much better gearing for track days than standard.Killerwhale wrote:Yeah, i want to go 17/42 instead of 16/39.
You have to get a TRX/TDM850 front sprocket and a TDM900 rear. Standard length chain (110 links?) will fit.
Cheers mate!
- Greg
I was in my friendly local Yamaha dealer today, and could he find a 16T front sprocket for me? Could he b*llocks!
In its OE configuration, there's no other sprocket listed as a direct 16T replacement for the standard item. The TDM sprocket has a different flange thickness (allegedly) so using one as a direct replacement on a TRX will cause chain alignment issues.
The other option is to use a 525 chain (or a 520 - whichever isn't standard) and get a chain/sprocket set....
What has anyone else done??
Greg.
Greg.
- billy budge
- trixynut
http://www.bandcexpress.co.uk and ace for all sprocket options: good prices, good service.
I'm running standard rear and 16 front. Cos the YZF rear wheel/180 tyre is bigger diameter it's about the same as standard gearing. Could do with going a bit lower really.
