How to off the rear disc.....
Post by Killerwhale » Wed Sep 12, 2007 4:42 pm
Any good tips on getting the rear disc off??
WD isn´t helping much.... :evil:
Found a new set of hex bits wich took a nice bite into screws....i almost broke my arm but hey...off it went! (lucky bastard!!)
billy budge
Post by billy budge » Wed Sep 12, 2007 5:41 pm
Ive always used an impact driver to get my discs off due to the standard bolts being made of cheese and always rounding off!!! :evil:
But all bolts are now titanium so no worries there anymore. :D
Sp!ke
Post by Sp!ke » Wed Sep 12, 2007 5:41 pm
You need a bigger breaker bar. :roll:
Post by youngy » Wed Sep 12, 2007 6:18 pm
I used an allen key. And lots of WD40. no problems.
Post by Greg » Wed Sep 12, 2007 6:26 pm
I have a windy gun which zipped mine off in double quick time after I realised that you have to push really hard to make sure the bits don't spin... :oops:
The one I f*cked up I had to bang a torx head bit into and then it eventually came out.
I replaced the front bolts with stainless jobs, but they came with a smaller hex, consequently they required careful handling to prevent the same thing happening...!
I'm interested in these Unobtanium bolts ... where from and how much?
:motard:
billy budge
Post by billy budge » Wed Sep 12, 2007 6:52 pm
For joe public greggy your looking at some daft money, approx £8 per bolt!!!!!!!!!!!!! :shock:
Fortunately i work in the aerospace industry and they are used like toilet paper in here, one trial fitting under a running torque and then binned!! :cry: So needless to say a lightfingered person could quite easily on night shift borrow some on a long term basis! :wink:
steve speed
Post by steve speed » Wed Sep 12, 2007 7:13 pm
be very careful ,,,heat the bolt area with a heat gun ,get a brass drift and when hot give the bolt a good whack downwards , use a good fitting alankey or if its rounded off tap in a torx key dont use to much force use a bit more heat and use stainless or titanium replacement bolts hope this helps ,,,( Ive done loads this way and it works )
Post by trixynut » Wed Sep 12, 2007 10:00 pm
....and sell them at a dead cheap price to his internerd mates??
Cash waiting!
Dave.
Janitor
Post by Max » Thu Sep 13, 2007 12:41 am
steve speed wrote:be very careful ,,,heat the bolt area with a heat gun ,get a brass drift and when hot give the bolt a good whack downwards , use a good fitting alankey or if its rounded off tap in a torx key dont use to much force use a bit more heat and use stainless or titanium replacement bolts hope this helps ,,,( Ive done loads this way and it works )
Yep, heat and whack. They are locktighted in there from the factory and over the years that stuff becomes granite. Use a good medium thread locker when you put them back in and you should be fine.
billy budge
Post by billy budge » Thu Sep 13, 2007 3:26 pm
Trixy - Next time on lates/nights i will see what i can do, keep you posted!! :lol:
Post by Greg » Thu Sep 13, 2007 3:33 pm
Put me on the list too BillyBobMatey!
:motard:
billy budge
Post by billy budge » Thu Sep 13, 2007 3:34 pm
No worries greg 8)
