changing front sprokets
steve speed
Re: changing front sprokets
Post by steve speed » Fri Feb 22, 2008 9:27 pm
mine was a new chain 110 links ,wheel was pushed forward but not up to the stop ,,it has 18mm of bolt showing on a 17_**_ 42 setup :D :D
cheesie
Post by cheesie » Fri Feb 22, 2008 9:35 pm
cheers phuk It is an old chain, I just want to try a few different combinations 16/39 on at the mo and the adjusters are near the end of the swingarm. the only 41t rear I can find is an alloy job
steve speed
Post by steve speed » Fri Feb 22, 2008 9:38 pm
go to bitsforbikes.co.uk they have them but i think 42t will be ok :D :D
kookimonsta
Post by kookimonsta » Sat Feb 23, 2008 4:44 pm
if it helps i can get steel rear sprockets 39t to 49t to fit the trx
Ride through the red mist, you will soon find the blue haze.
pwmotorsports
Post by pwmotorsports » Sat Feb 23, 2008 6:53 pm
whats a steel 42 gonna cost then bud ?
steve speed
Post by steve speed » Sat Feb 23, 2008 7:20 pm
£20.50 from bitsforbikes.co.uk
Post by phuk72 » Sat Feb 23, 2008 7:23 pm
And about the same from B&C Express
Post by Quan-Time » Sun Feb 24, 2008 12:05 pm
17/43 here.. Sure its a bit peaky, but 3rd gear @ 60km/h is fine..
least i THINK its 43.. either way.
kookimonsta
Post by kookimonsta » Sun Feb 24, 2008 12:24 pm
I can do you one for £19.80 but it will be plus the post. (which you will have to pay from b&c etc. i will do post at cost)
pm me if you want it!
tom
pwmotorsports
Post by pwmotorsports » Sun Feb 24, 2008 12:26 pm
what other model sprokets will fit? TDM ? FZR? YZF?
Post by youngy » Sun Feb 24, 2008 12:30 pm
See that Search button??????? TDM900 is the same.
TDM850 will not fit. YZF750 fits but they are huge.
steve speed
Post by steve speed » Sun Feb 24, 2008 12:33 pm
^^^^^^^^ what he said [-X [-X
pwmotorsports
Post by pwmotorsports » Sun Feb 24, 2008 1:25 pm
well in my defence i cant spell for crap and spelling it wrong means no suitable search results........
Dont mock the afflicted its not nice :oops:
pwmotorsports
Post by pwmotorsports » Fri Feb 29, 2008 7:42 pm
fitted a 42 feels nice allthough had a 41 fitted allready
thumpa
Post by thumpa » Mon Apr 28, 2008 4:49 am
in reading the above (not sure if i read right), i have stock gearing and chain is a little worn, can i just fit a 42t rear sprocket without any problems? i want to check the gearing is ok before i fit a new chain.
i have contemplated between 16/39 or 17/42 even a 16/40 and from the gearing calculator i see the 42t rear will be a little more revyer (probably un noticable) but since i mainly ride around town and alot of stop/starting, red light racing etc.. this will be good for me.
