Ignition barrel removal.
Post by trixynut » Tue May 20, 2008 9:35 pm
Any ideas on how to remove the two roundy-headed bolts underneath the ignition barrel to free it from the top yoke?
Re: Ignition barrel removal.
Post by youngy » Tue May 20, 2008 9:51 pm
you have to drill them - they're shear bolts.
I might have a top yoke with the switch already removed if it's any help to you.
Post by trixynut » Wed May 21, 2008 9:23 am
Ta, but it's the ignition barrel I want, so I can put it in the YZF top yoke.
If I drill off the top of the bolt, Can I then slip off the barrel, and I'll be left with two threaded bolt stubs sticking out of the yoke?
Post by youngy » Wed May 21, 2008 10:17 am
yes that's the idea.
i twigged what you were doing after I posted d'oh!
burty
Post by burty » Wed May 21, 2008 11:40 am
I welded a nut on the top of mine then turned them out with a spanner.
Post by Tarwetijger » Wed May 21, 2008 3:10 pm
No you can turn out the bolt stubs as well! The only thing is it will be a little difficult if they were placed with loctite, but do-able.
steve speed
Post by steve speed » Wed May 21, 2008 5:39 pm
i drilled two small holes in mine then used the circlip pliers to get them out mine were not that tight
honkdawillydahonk
Post by honkdawillydahonk » Wed May 21, 2008 7:21 pm
trixynut wrote:...Ta, but it's the ignition barrel I want, so I can put it in the YZF top yoke.
Are you sure it'll fit? I'm pretty sure it doesn't.... #-o
Drill a small pilot hole and then open up to 6.5mm or so... The head should come away and leave the shank behind.
Post by trixynut » Fri May 23, 2008 9:45 am
..yep, it does.
..and so does the new front end..
steve speed
Post by steve speed » Fri May 23, 2008 10:12 am
looking good ,,did you service the forks before you fitted them ?? if they are R1 ,,10w oil and 80mm air gap :D :D
Post by trixynut » Fri May 23, 2008 10:18 am
Cheers Steve, but they're YZF750, and yep, I serviced them, with some difficulty before a link to the Haynes manual online was posted up: see other thread!
honkdawillydahonk
Post by honkdawillydahonk » Fri May 23, 2008 6:38 pm
..yep, it does.
Good news! (Now I come to think of it, I replaced mine because it was fecked....)
Looking good! :D
Wombat
Forum Marsupial
Post by Wombat » Sun Jun 29, 2008 1:02 am
Yeah, I gotta do this soon. The key and barrel are getting very notchy and hard to turn. Gonna try the cheap option and get some keys cut first but if that dont solve it, I'll have to get a new barrel and keys. Finding it very hard to unlock it off the steering lock. What fool put the connector underneath the tank, though :evil:
PS could you similar bolts back in there but with, say torx or allen heads instead of shear bolts?
honkdawillydahonk
Post by honkdawillydahonk » Sun Jun 29, 2008 6:36 pm
Wombat wrote:.... What fool put the connector underneath the tank, though :evil:
It'd be a bit too easy to hotwire if it was anywhere easy to get at dontchathink? :shock:
Wombat
Forum Marsupial
Post by Wombat » Sun Jun 29, 2008 9:07 pm
when you think of it that way, Honk, yes it would, i 'spose :shock: :oops:
BTW how much are they new?
