Just wondered if any of the cleverer forum members could make any suggestions as to likely areas to investigate? I will probably be paying someone to fix the problem, as I need the job done quickly (commuter bike) and properly, but would like to be able to point them in the right direction, and not give them an excuse to do more than is necessary.
As there are no clouds of smoke, no obvious oil contamination and no 'orrible noises, is this most likely to be just one or more of the rings finally giving up and allowing more and more oil into the combustion chamber to be burned?
Also, if it will end up needing (at least) the head taking off, any suggestions on things to fix or upgrade while it's apart? I think I recall that a mild performance cam is pretty much pointless without porting, polishing and a lot of airflow work on the intake and exhaust side of things. Similarly, I guess the old 29cc overbore is only worth it if the liner's shot (someone will now point out that the TRX mill is linerless, no doubt) or you're doing a shedload of other work?
Thanks in advance...
