fcr main jets
- steve speed
fcr main jets
what is every one using size wise for the main jet ?? i think mine is a bit lean ,,,i went for a long ride today and on WOT when you throttle back about a quarter it picks up so i am thinking its a bit lean it has ram air pod filters on and a big bore exhaust and quill T3 cans done a search and some are bigger and some smaller main jets
main jet is 155 at the moment is there some settings for a std motor ??? HELP !!! O and they are 41s
- dillthedog
Re: fcr main jets
i have 160 mains
- honkdawillydahonk
Re: fcr main jets
I'm on 170s with foam filters.... And I was on about 148s with the (modded) airbox. 155 sound about right.
- steve speed
Re: fcr main jets
i cant see how 155 can be right because as i said as you roll the throttle back from full it picks up so to me thats lean
where,s the best place to get some more jets ?
- Killerwhale
Re: fcr main jets
I buy all carb related stuff from allens performance (steve)steve speed wrote:i cant see how 155 can be right because as i said as you roll the throttle back from full it picks up so to me thats lean![]()
You can also drill them out, Keihins numbers are mm....155=1,55mm
- steve speed
Re: fcr main jets
thanks to all that replied to this and the pm,s ,,,,iam going to give alans a ring see if they have any recommendations
- Killerwhale
Re: fcr main jets
They also make velocity stacks wich has a bulge over the main air jet/air screw to keep crud out of the carbs/engine.steve speed wrote:thanks to all that replied to this and the pm,s ,,,,iam going to give alans a ring see if they have any recommendations![]()
All their aftermarket stuff is 20£/pc....super service although Steve made a "ohh, what was i thinking" once...
- phuk72
Re: fcr main jets
Blimey - I'm on 158s with K&N podshonkdawillydahonk wrote:I'm on 170s with foam filters.... And I was on about 148s with the (modded) airbox. 155 sound about right.
- honkdawillydahonk
Re: fcr main jets
Ooops. Wasn't really paying attention... Does it go better on choke out of interest?steve speed wrote:i cant see how 155 can be right because as i said as you roll the throttle back from full it picks up so to me thats lean![]()
Got my jets from Allens. Bit pricey though..... About £12 a pair!
- Kayla
Re: fcr main jets
Cheaper than a holed piston thoughhonkdawillydahonk wrote:Ooops. Wasn't really paying attention... Does it go better on choke out of interest?steve speed wrote:i cant see how 155 can be right because as i said as you roll the throttle back from full it picks up so to me thats lean![]()
- honkdawillydahonk
Re: fcr main jets
It's not exactly a FSIE....Kayla wrote:Cheaper than a holed piston thoughhonkdawillydahonk wrote:Ooops. Wasn't really paying attention... Does it go better on choke out of interest?steve speed wrote:i cant see how 155 can be right because as i said as you roll the throttle back from full it picks up so to me thats lean![]()
- phuk72
Re: fcr main jets
Choke on FCR41s?honkdawillydahonk wrote:Ooops. Wasn't really paying attention... Does it go better on choke out of interest?steve speed wrote:i cant see how 155 can be right because as i said as you roll the throttle back from full it picks up so to me thats lean![]()
- Greg
Re: fcr main jets
If you need FCR jets cheapish, Alex at: smebike@ihug.co.nz has supplied all of mine at about £6.00 per pair delivered from NZ - everything I've ordered has arrived withing 5 days..Top Bloke!
G
G
- honkdawillydahonk
Re: fcr main jets
Road ones have a choke don't they?phuk72 wrote:Choke on FCR41s?honkdawillydahonk wrote:Ooops. Wasn't really paying attention... Does it go better on choke out of interest?steve speed wrote:i cant see how 155 can be right because as i said as you roll the throttle back from full it picks up so to me thats lean![]()
- phuk72
Re: fcr main jets
Dunno? Not seen any with a choke?honkdawillydahonk wrote: Road ones have a choke don't they?
