fcr main jets
steve speed
fcr main jets
Post by steve speed » Sat Sep 20, 2008 8:48 pm
what is every one using size wise for the main jet ?? i think mine is a bit lean ,,,i went for a long ride today and on WOT when you throttle back about a quarter it picks up so i am thinking its a bit lean it has ram air pod filters on and a big bore exhaust and quill T3 cans done a search and some are bigger and some smaller main jets :? :? :? :? main jet is 155 at the moment is there some settings for a std motor ??? HELP !!! O and they are 41s
dillthedog
Re: fcr main jets
Post by dillthedog » Sat Sep 20, 2008 9:52 pm
i have 160 mains
honkdawillydahonk
Re: fcr main jets
Post by honkdawillydahonk » Sun Sep 21, 2008 7:59 am
I'm on 170s with foam filters.... And I was on about 148s with the (modded) airbox. 155 sound about right.
steve speed
Re: fcr main jets
Post by steve speed » Sun Sep 21, 2008 9:36 am
i cant see how 155 can be right because as i said as you roll the throttle back from full it picks up so to me thats lean :? :? where,s the best place to get some more jets ?
Re: fcr main jets
Post by Killerwhale » Sun Sep 21, 2008 12:04 pm
steve speed wrote:i cant see how 155 can be right because as i said as you roll the throttle back from full it picks up so to me thats lean :? :? where,s the best place to get some more jets ?
I buy all carb related stuff from allens performance (steve)
You can also drill them out, Keihins numbers are mm....155=1,55mm
steve speed
Re: fcr main jets
Post by steve speed » Sun Sep 21, 2008 1:06 pm
thanks to all that replied to this and the pm,s ,,,,iam going to give alans a ring see if they have any recommendations :D :D :D
Re: fcr main jets
Post by Killerwhale » Sun Sep 21, 2008 3:30 pm
steve speed wrote:thanks to all that replied to this and the pm,s ,,,,iam going to give alans a ring see if they have any recommendations :D :D :D
They also make velocity stacks wich has a bulge over the main air jet/air screw to keep crud out of the carbs/engine.
All their aftermarket stuff is 20£/pc....super service although Steve made a "ohh, what was i thinking" once...
Re: fcr main jets
Post by phuk72 » Sun Sep 21, 2008 4:44 pm
honkdawillydahonk wrote:I'm on 170s with foam filters.... And I was on about 148s with the (modded) airbox. 155 sound about right.
Blimey - I'm on 158s with K&N pods
honkdawillydahonk
Re: fcr main jets
Post by honkdawillydahonk » Sun Sep 21, 2008 5:36 pm
Ooops. Wasn't really paying attention... Does it go better on choke out of interest?
Got my jets from Allens. Bit pricey though..... About £12 a pair!
Kayla
Re: fcr main jets
Post by Kayla » Sun Sep 21, 2008 5:46 pm
Cheaper than a holed piston though :wink:
honkdawillydahonk
Re: fcr main jets
Post by honkdawillydahonk » Sun Sep 21, 2008 5:50 pm
It's not exactly a FSIE.... :lol:
Re: fcr main jets
Post by phuk72 » Sun Sep 21, 2008 6:41 pm
Choke on FCR41s?
Re: fcr main jets
Post by Greg » Sun Sep 21, 2008 7:03 pm
If you need FCR jets cheapish, Alex at: smebike@ihug.co.nz has supplied all of mine at about £6.00 per pair delivered from NZ - everything I've ordered has arrived withing 5 days..Top Bloke!
G
:motard:
honkdawillydahonk
Re: fcr main jets
Post by honkdawillydahonk » Sun Sep 21, 2008 8:20 pm
Choke on FCR41s?
Road ones have a choke don't they? :?
Re: fcr main jets
Post by phuk72 » Mon Sep 22, 2008 8:02 am
honkdawillydahonk wrote: Road ones have a choke don't they? :?
Dunno? Not seen any with a choke?
